Topic: $$ clock code (Read 1 time) previous topic - next topic
bazzapromenade
I am looking to pay someone to write some clock code
hardware -: arduino, lcd, RTC (based on any of the common I2C rtc chips) , 3 or 4 input switches, 2 output pins.
Specs'
clock is used to operate a door lock.
 4 times needed to allow/disallow entry or exit through door
time 1 allows start of enter time - output A high
time 2 stops enter time  -  output A low
time 3 allows start of exit time - output B high
time 4 stops exit time - output B low
upon power up of arduino lcd ask to set current time
this is to be done manually not by computer when uploading sketch.
4 entry/exit times are stored in eeprom current time can be volatile.
inputs used to toggle between and the setting of current time, enter start time, enter stop time, exit start time, exit stop time.
lcd used for setting of times only, once times are set lcd turns off to save battery power.
pressing any input button turns lcd back on.
time to be presented in 12 hour format am/pm
day/date not required. entry/exit times are the same every day 365 days per year
do not care which pins are used for inputs and outputs
patduino
Hi bazzapromenade,
Just curious - What type of door lock do you have planned?
Pat.
There are 10 types of people in the world, those who understand binary, and those that don't.
6v6gt
What about automatic compensation for daylight saving time ?
bazzapromenade
Patduino thanks for your pm.
Its for a particular entry turnstyle that can be set to allow entry into a building only during preset hours and also exit during different preset hours. The rest of the time entry or exit can be denied through this particular rout.
Daylight savings compensation will not be required.
rdpoor
Hi @bazzapromenade - Look for a PM from me about this project.  Thanks.
