Topic: Is this a good budget soldering iron? (Read 6327 times) previous topic - next topic
CanadianCyanide
So I'm an Arduino beginner and after doing some basic projects I'll be starting my own more advanced projects, and I'll need a soldering iron for some of them. I found this soldering iron + solder combo and it looks pretty good. I'll be pairing it with this helping hand/magnifying glass/soldering iron holder combo. This is the solder it comes with as far as I know. Does rosin core mean it comes with flux, or do I need to buy some separately? And is the soldering iron any good? Thanks in advance to anyone who replies.
INTP
#1
Oct 01, 2016, 10:55 pm Last Edit: Oct 01, 2016, 10:59 pm by INTP
Generic rebranded soldering iron. It will work just fine. The tips it comes with will probably literally only last a job or two as they disintegrate, but it takes Hakko tips which work great.
I would buy a proper stand for the iron, a brass wool in a can for tip cleaning, and 63/37 solder.
Rosin core means it has flux in the middle of the wire, which is fine for just about everything you'll do. Unless you plan on working on some grody oxidized components from decades ago, it should be all the flux you need in there.
And you're right that it comes with 60/40 solder, but it is definitely not going to be kester. Whatever it comes with will be usable, but you should look for good solder (such as kester 63/37) as that makes the most difference in your results.
CanadianCyanide
Which tips specifically should I be getting? I don't really want to spend more than the $20 for the iron and $14 for the third hand/stand/magnifier unless the tips that come with the iron will really disintegrate.
ArduBogus
Really? when using rosin core i don't need to use flux to solder? that's my dream thing!
And when it comes to clean the board after, do you recommend anything?
I always had this doubt but never remembered to ask.
Thanks!
INTP
https://www.hakko.com/english/tip_selection/series_900m.html
I'm using no-name Hakko 900M series tips on what's probably the same soldering iron you showed. No complaints, just never really want to lug out the big Weller station for the quick jobs I do.
INTP
Thanks!
You don't need additional flux usually. The rosin in the core is flux. Not a bad idea to have some extra flux, but I haven't even cracked open mine yet.
Paul_KD7HB
IF you use rosin core solder, you don't need to clean the boards. If you still want to, use IPA (isopropal alcohol). We buy the cheap stuff at a drug store and use an old tooth brush. Wash the board with hot water and air dry to finish cleaning.
If using any other type of flux, wash in hot water and air dry.
If you are adding a something that can't be washed, add that after washing and use "no clean" flux.
Paul
Jiggy-Ninja
Paul
FYI, most things that cannot be washed will be mechanical things, like switches or relays that aren't sealed, or something like an atmospheric sensor with an open port. The thing these have in common is little nooks and crannies that the cleaning gunk can easily get into, but not so easily removed.
Most electronics components won't care about being washed, as long as they are dried before powering up.
Using the Hakko page that INTP linked, your best general purpose tip is going to be a shape D chisel tip, probably the 1.6D or 2.4D.
Also, do not forget solder wick and a solder sucker.
Do not forget to get solder wick. I said it twice because it's important.
dwightthinker
#8
Oct 02, 2016, 05:47 am Last Edit: Oct 02, 2016, 08:02 am by dwightthinker
I don't like this type of iron because the tip is not grounded.
Most part don't have problems but a part that is commonly use
with arduinos is very sensitive and easily damaged with an ungrounded
tip of a soldering iron. That part is a MOSFET.
One of the other thread started about just such a problem.
The tips of these iron has a small capacitance to about 1/2 the line voltage.
Most parts have protection that can easily handle this small of
a capacitance. The MOSFET's input is essentially a capacitor. A small
capacitor. The voltage of the ungrounded iron can easily go over 70
volts, damaging the gate lead.
Dwight
Wawa
Direct powered irons shouldn't be used for electronics.
They are only good for wires, connectors, etc.
Sensitive electronics need an ESD-safe soldering station.
Leo..
Wawa
If you want to solder a mosfet safely with a cheap hot poker, do this.
Use a thin bare copper wire to connect/short all pins of the mosfet together, close to the body.
When the mosfet is soldered in, remove the wire.
Leo..
CanadianCyanide
Dwight
Can you recommend a good iron sold on a Canadian website?
Would https://www.amazon.ca/SODIAL-Aluminium-Desoldering-Solder-Remover/dp/B00JFOR9G0/ref=sr_1_1?s=hi&ie=UTF8&qid=1475415878&sr=1-1&keywords=solder+sucker and https://www.amazon.ca/MG-Chemicals-424-LF-Temperature-0-05-Inch/dp/B008O9WEUS/ref=sr_1_12?s=hi&ie=UTF8&qid=1475416071&sr=1-12&keywords=solder+wick work?
Paul_KD7HB
Leo..
Don't jump to conclusions without checking with an Ohmmeter. If they have a 3 wire power cord, the tip is grounded. Look for the UL label.
Paul
dwightthinker
I would assume one can by a Weller soldering station in Canada.
It won't be a cheap as the you you got.
Dwight
Jiggy-Ninja
#14
Oct 03, 2016, 05:12 am Last Edit: Oct 03, 2016, 05:14 am by Jiggy-Ninja
Yep, exactly the kind of thing I was talking about.
I bought a used Hakko FX-888 for 60 USD off ebay a few years ago. SSSOOOOOO much better than the worthless fire starters that just plug into mains. You should be able to find a Hakko or Weller for a good price if you hunt well enough. Even an older model will still work fantastically.
Also, the iron holder on that third hand thing is worse than worthless, it is dangerous. Never, EVER use a holder with a base with such a small footprint like that, it will have no stability at all when the weight of the iron is on it. It'll tip easier than an alcoholic after a night at the bar, and then your 350oC iron is rolling around on the table, maybe falling off the table, who knows?
Any proper soldering station will have a big, chunky iron stand that has no chance of tipping over. My Hakko one has some proper weight in it, I could probably club a burglar unconscious with it. I cannot stress enough to never use that crappy thing attached to your third arm that claims to be an iron stand.
