Topic: Will pay for arduino code (Read 3521 times) previous topic - next topic
lavellhicks
Looking to pay someone to write an arduino "follow me" code using the arduino pieces that I currently have. I'm a beginner and the project is a bit advanced for my time frame. I want my rc car to follow me wherever I go. If interested let me know and I will go into more detail.
patduino
Hi lavellhicks,
I think your plan to break the project into smaller pieces is an excellent idea.
What sensors do you plan to use? How will the car know where you are?
Pat.
There are 10 types of people in the world, those who understand binary, and those that don't.
blimpyway
I think a mechanical device is the simplest and most accurate way to make a follow-me cart. Think of a retractable dog leash but much lighter, with a rotary encoder and potentiometer will measure quite well direction and distance between cart and the person pulling it.
PaulS
Quote
That presumes that the pieces that you have are appropriate. Without knowing what those pieces are, I, for one, am not willing to agree that they are appropriate.
PaulMurrayCbr
OP: please tell us what pieces you already have, what method your device will use to follow someone. After all - you could accomplish this without any arduino at all simply by attaching a dogleash and dragging the thing around. If that's not what you had in mind, to even decide whether or not I might be able to do your coding, I have to know what you are thinking of.
lavellhicks
Apologize for the late response but i want the car to use GPS to always know where I am. So far I have two bipolar stepper motors, arduino uno, and an adafruit ultimate gps logging shield for the car. (a motor shield as well if needed but highly doubt it). I have a ultimate gps breakout and an arduino pro mini to be used for the tag.
blimpyway
The GPS is quite inacurate. It will follow you when distances are greater than few (3-5) meters, but
- it won't  follow you exactly, any nearby obstacles (like when you pass through a gate) might not be avoided,
- GPS signal may be shadowed in certain places - near trees, tall buildings, indoors.
- you didn't mention a communication means between tag and follower.
Dmitron1036
I guess, optical IR-receiver 36kHz IC on servo-motor - will scan the space.
and ultrasonic distance meter will show you the distance.
IR transceiver can be on enother arduino (on you).
lavellhicks
Not as concerned about objects in the way. But I am concerned with the accuracy. IR receiver sounds about right as long as it can reach up to 45-50 yards
lavellhicks
I'm willing to change the hardware. Just need someone to take the project on.
blimpyway
Quote
Being concerned without mentioning what  accuracy has to be, is not very useful.
Quote
That's a strange environment. Can you be more specific about
- what this environment is
- how close the vehicle should follow its target
Quote
It might be for anyone, what is the time frame?
A couple ultrasound sensors + triangulation might be useful, eventually with IMUs to compensate for ultrasound's inconsistent reliability (but hopefully without).
Without details about vehicle and its environment  no one can tell what are the chances to solve it in an unknown time frame.
lastchancename
Just to toss in another wrinkle - you mention significant distances (and possibly terrain), suggesting the car may get up to a modest speed while looking for you and navigating/approaching.
You need to handle the steering angle, acceleration & braking as well as obstacles and distance to calculate any meaningful navigation strategy.  Also consider movable challenges - a dog, stroller etc.
Running over those distances for an extended period of time at speed will require substantial batteries (=weight), so larger motors (=larger batteries = larger motors=larger batteries...) may be needed.
Is this simply a toy to follow you around while you play soccer, or a planned project with an end goal (excuse the pun!).   We need more info, as well as your location, as that may rule out contributing to your learning curve.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
rfowler416
    This is almost exactly what I'm looking for.  I want a cooler to follow me as I walk from my truck to the softball field, beach, etc.  I'm an experienced licensed electrician, and a chronic tinkerer, so I can build and wire the thing easily, and I have boxes and boxes of Arduino and Raspberry Pi hardware and sensors sitting around.  I simply don't have the expertise or time to code and program the thing (having twins a few years ago sort of halted my learning this stuff).
     My plan is to use a 3-wheeled setup.  I will either have one motor to drive the rear wheels and a servo or actuator to turn the single front wheel, or use a motor on each rear wheel and steer by stopping or slowing one motor at a time.  That stuff is easy enough for me to handle, but how to make it follow me is what I'm having difficulty with.  It will be used in the open and as a sort of novelty, so obstacle avoidance, complex navigation, and high speed won't be terribly necessary.  I would think a beacon (IR or ultrasonic) would be the easiest thing, but I don't know how to code it.  I'm trying to do this fairly cheaply, hardware-wise, but I'd gladly pay some one of you experts out there to write the code for me so I can just upload it and maybe reverse engineer the thing a bit as I learn.  Thanks in advance.
Delta_G
How much you willing to pay?  That sounds like a pretty involved undertaking.  Won't be cheap.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
romalomey
#14
Sep 12, 2019, 10:21 pm Last Edit: Sep 12, 2019, 10:22 pm by romalomey
What is the magic that caused this topic to be
read 1600+ times? :)
