Topic: Mac Crashes when pulling-in any arduino baord after upgrade to Sierra (Read 4521 times) previous topic - next topic
avnerg
after working heavily with Arduino IDE with previous versions of MacOS,
My MacPro crashes when i plug in the arduino board USB cables, regardless if Arduino IDE is open or not.
During boot it will crash again until i plug off the Arduino cable.
tried to upgrade to the recent Arduino IDE, tried different USB cables, different Arduino boards. same results.
any ideas ?
Crash logs attached.
rpt007
This is reported when using an Arduino clone with CH340 chips on board and "old" drivers.
Here:
https://github.com/adrianmihalko/ch340g-ch34g-ch34x-mac-os-x-driver
it is explained how to remove the old river and a place to download a "Sierra compatible" driver.
I can't tell if that really works, but I read some comments of successful repairs. One guy said, he used a "better" USB cable, which solved the problem. Ok - I am still on Yosemite and wait to jump to Sierra only, when I find less reports on Sierra / Arduino crashes as I a have a mix of originals and clones.
Before you ask:
Did you really read and understand How to use this forum ?
AND:
Do you have already some solution or is a part of the problem sitting in front of the screen?  :)
AntInvent
This should help:
https://www.simplicate.info/2016/09/16/ch340-drama-osx-10-12-sierra-16a313a/
rpt007
@AntInvent:
Original poster hasn't come back for a while -. so he might have either found a solution or given up.
Your link is ok, but it should be used in conjunction with the link to Yu Wang's reply (new driver installation).
Before you ask:
AND:
hmfifty
The link provided by rpt007 solved my problem.
Thanks for the help folks!   :)
