Topic: VirtualDelay (Read 8252 times) previous topic - next topic
avandalen
#15
Sep 04, 2017, 05:01 pm Last Edit: Sep 05, 2017, 08:46 am by avandalen
----- IMPORTANT -----
The library has been completely rewritten because there was a bug in the function proceed(). see:
http://www.avdweb.nl/arduino/libraries/virtualdelay.html
rhubka
Thanks avandalen
I've downloaded your updated Delay library from Github
Github
I'm going to start playing with it.
The thought of the Delay() stopping code execution drives me crazy. >:(
Cheers
Rick Hubka
sechen
Hi!
Does it work with Leonardo?
According description it's great but can't compile
avandalen
Thanks avandalen
Github
Cheers
Rick Hubka
try the new version, everything is tested
avandalen
Hi!
yes AVR and SAMD21
TonyWilk
I'm sure we're in 'better mousetrap' territory here and these things are prone to personal preferences, but here's my view...
On your linked page, you ought to have several examples of your library which tries to show how it simplifies the code and makes it more readable.
At the moment it seems to show how much of an unreadable nightmare you can create.
In your post you give:
{ if(virtualDelay.done(500)) digitalWrite(ledPin, b=!b); // the LED blinks on and off
and on the page:
{ singleDelay.start(400); // calls while running are ignored
  if(singleDelay.elapsed()) digitalWrite(ledPin, b=!b); // blink the onboard LED 400ms, 400ms off
...which just highlights to me that there is a problem in using this library and making it obvious and readable.
Having hidden functionality and/or side-effects to methods which requires you to comment it just to save a line of code is not a good idea.
I'd prefer:
if( singleDelay.stopped() )
  singleDelay.setRepeatingInterval(400);
if( singleDelay.elapsed() )
  //do the LED thing
Yours,
  TonyWilk
avandalen
Dear Tony
Thank you for your comments, I always like to hear if something can be improved
There is no virtualDelay.done  function anymore in the new version:
>> I'd prefer:
  //do the LED thing
Yes, that looks good, but I have no time to rewrite the library. Maybe we can change just the names of some functions to make it better understandable?
TonyWilk
Yes, I think that the actual names of methods can make a great deal of difference to the usability of a class.
In some cases it might be handy to simply provide some aliases for different use-cases (I know there are different opinions on this)
for example:
myclass.setTimeout( 250 );
if( myclass.hasTimedOut() )
myclass.setRepeatingInterval( 100 );
if( myclass.intervalHasElapsed() )
... could be that hasTimedOut() and intervalHasElapsed() are internally identical.
Yours,
 TonyWilk
avandalen
for example:
Note that DO_ONCE is still needed sometimes.
Can you please change the 5 examples with your function names?
for example:
I'm curious how your idea will work with the 5 examples in:
Can you test it with the 5 examples? (Note that DO_ONCE is still needed sometimes)
