Hello,
i try to use the Genuino MRK1000 as a controller of 12 MOSFETs (
RFP12N10L) to control peltier elements with the PWM pins, which are connected to the source of the MOSFETs with an external power source. The schematic shows the setup of the circuit.
The problem is, that when I connect the Genuino to the circuit it outputs a lower voltage the more pins I activate. Not connected to the circuit it always outputs the full 3.3V. I narrowed the problem down a bit, with leaving the peltier elements and the extra power source out.
I am really no expert in electrical engineering, so I'm assuming it might be a problem with the circuit setup itself, but Im not sure. I'd really appreciate help, thank you in advance!
-> PROBABLY SOLVED!
After a bit trial and error testing I think I found the solution to my problem. The 10k resistor was too small. I changed it to a 470k resistor and am now getting the full 3.3V on every pin, regardless of how many are active at the same time.
