Topic: Rotary encoder midi! (Read 10674 times) previous topic - next topic
bakonyip95
Oct 11, 2016, 11:05 am Last Edit: Oct 11, 2016, 11:13 am by bakonyip95
Hi!
I would like to make a midi device Rotary encoder. I have added an Arduino UNO board. I would like you to deal with Ableton and Traktor and other DAW software.
I found a seemingly good code, but teensy board was written and gives a lot of mistakes. I have an Arduino Uno board and I want to use.
Can you help me to know what the code change that?
Code: [Select]
#include <Encoder.h>
Encoder enc_one(2, 3);
int value;
long enc_one_previous  = -999;
byte button_previous;
 pinMode(23, INPUT_PULLUP);
 value = enc_one.read();
 if(value > 127) {    enc_one.write(127);   }
 else if(value < 0) {    enc_one.write(0);  }
 value = constrain(value, 0, 127);
 if (value != enc_one_previous) {    enc_one_previous = value;    usbMIDI.sendControlChange(1, value, 1);  }
 value = digitalRead(23);
 if(value != button_previous) {    button_previous = value;    usbMIDI.sendControlChange(2, (1 - value) * 127, 1);    delay(3);  }
PieterP
#1
Oct 11, 2016, 07:40 pm Last Edit: Oct 11, 2016, 07:42 pm by PieterP
The Uno doesn't support MIDI over USB like a Teensy does. You can get it to work by flashing custom firmware to the on-board ATmega16U2. I explained everything in this article: Custom Arduino MIDI Controller. You can find example sketches as well, or you could check the source files of the library, to see how I implemented it.
The MIDI_Controller library (download it from the link above) includes this very simple example:
Code: [Select]
#include <MIDI_controller.h>
const static byte Channel = 1;
const static byte Controller = 0x14;
RotaryEncoder enc(2,3,Controller,Channel,1,JOG,POS1_NEG127); // Create a new member of the class 'RotaryEncoder', called 'enc', on pin 2 and 3, controller number 0x14, on channel1, no change in speed (speed is multiplied by 1), it's used as a Jog wheel, and the mode is set to POS1_NEG127.
void setup(){
  setupMidi(13, 10); // Setup the MIDI communication, with an LED on pin 13, and a delay of 10ms after every message.
void loop(){
  enc.refresh();
Pieter
bakonyip95
I use Moco Dual technologie. I wish you the rotary encoder would have values between 1 and 127.
But I have not found a solution. Can someone help me on this?
PieterP
Did you read steps 10 & 12 ? A rotary encoder is a relative positioning device, and there's at least 3 ways to convert its movement to relative MIDI messages (between 0 - 127), the library supports three different modes, just experiment what works with your DAW.
If you just want a knob that goes from 0 - 127, depending on the absolute position, you need a potentiometer.
Pieter
bakonyip95
I need rotary encoder because it is push button! :)
I tried a variety of code already, but none of them worked perfectly well. :(
bakonyip95
The library said midi give these mistakes:
Code: [Select]
C:\Users\...\Documents\Arduino\libraries\MIDI_controller\Analog.cpp: In constructor 'Analog::Analog(byte, byte, byte, byte)':
C:\Users\...\Documents\Arduino\libraries\MIDI_controller\Analog.cpp:11:6: error: 'dPin' was not declared in this scope
   if(dPin < A0 || dPin > A5){ //If the user enters an invalid pin number.
exit status 1
Error compiling for board Arduino/Genuino Uno.
PieterP
My bad, I had made some changes to the code for the Arduino Leonardo and forgot to change the code for the Uno, resulting in different variable names (dPin should be p). I uploaded a new version: delete the old library and download + install the new version.
I tried it and it works just fine now.
Pieter
bakonyip95
Excuse me, but now I can not find the MIDI_controller.zip website. Can you help that I download from?
Thanks!
PieterP
Thanks!
Here ya go: http://www.instructables.com/id/Custom-Arduino-MIDI-Controller/step13/The-Library/
bakonyip95
Thanks, managed to write on, but does not communicate with MIDI port. I use DualMoco USB firmware, which is to usb midi device. How can I solve that information to send MIDI port on the device?
PieterP
I changed the baud to 115200 to test it, and forgot to change it back to 31250. That should be fixed now, so I hope it'll work after reinstalling the library.
Sorry about that.
Pieter
bakonyip95
So you have to communicate, but it is the next problem:
It works with the shooting, but wherever rotated only increases the value never decreases. Why is this possible?
PieterP
#12
Oct 12, 2016, 02:53 pm Last Edit: Oct 12, 2016, 02:54 pm by PieterP
You have to select the right settings in your DAW, for example in Reaper, you have to select the relative CC mode:
bakonyip95
It is selected, unfortunately, many do not have the option Tractor
PieterP
Traktor does support it, read the instructions here.
The MIDI controller library allows you to change the encoder mode as well:
Code: [Select]
RotaryEncoder enc(2,3,Controller,Channel,1,JOG,POS1_NEG127); // corresponds to Traktor encoder mode "7Fh/01h"
RotaryEncoder enc(2,3,Controller,Channel,1,JOG,ADD_64); // corresponds to Traktor encoder mode "3Fh/41h"
Quote
ADD_64
First mode for relative MIDI messages. This is probably the simplest one. This basically maps 0 to 64 (which is 128/2). For example, if I want to send -1, I add 64, = 63 and I send it. If I want to send +1, I also add 64, = 65. If I just send 64, the computer will do nothing, because it knows it's a displacement of 0. (On the computer side, they just subtract 64, and you can use the result like nothing ever happened.)
SIGN_BIT
Second mode for relative MIDI messages. On computers, signed values are mostly saved with a sign bit. The sign bit is the most significant bit. When it's 0, the number defined by the other bits is positive, when it's 1, the number is negative. In a MIDI message, this is bit 6 (the 7th bit, since it's 0 based). For example: +4 would be 0b00000100, and -4 would be 0b01000100.
POS1_NEG127
Third mode for relative MIDI messages. Define +1 as 1, and -1 as 127. We can continue this: +2 = 2, and -2 = 126, etc. until +63 = 63, and -63 = 65.
Side note: It's better to use the NORMAL_ENCODER option: it will send 1 message per click, instead of 4, this will be smoother:
Code: [Select]
RotaryEncoder enc(2,3,Controller,Channel,1,NORMAL_ENCODER,POS1_NEG127);
Quote
RotaryEncoder(byte pin1, byte pin2, byte controller, byte channel, int speedMultiply, byte pulsesPerStep, byte mode);
pulsesPerStep is the number of pulses the encoder outputs when you turn it one step or click. On a normal rotary encoder, this is 4. When you set it to 4, it will change 1 unit in your software per click you turn, instead of 4. This is mostly more logical. For jog wheels however, you may want to set it to 1, to take advantage of the full resolution of the wheel. Use 'NORMAL_ENCODER' or 'JOG' as argument.
NORMAL_ENCODER
set pulsesPerStep to 4, for normal rotary encoders.
JOG
set pulsesPerStep to 1, for jog wheels.
If you really want an absolute mode, just let me know, and I'll add it to the library.
Pieter
