Topic: Playing .wav file from arduino uno (Read 3496 times) previous topic - next topic
BangmanHackerman
Oct 11, 2016, 03:19 pm Last Edit: Oct 11, 2016, 03:28 pm by BangmanHackerman
I need to play a .wav file from a arduino uno for a science project, but i keep getting stuck on the code. I'm an absolute beginner to programming and really need help! sorry if this is something super easy to fix and I'm just to dumb to fix it.
Here is my code
Code: [Select]
#include <SD.h>                      // need to include the SD library
//#define SD_ChipSelectPin 53  //example uses hardware SS pin 53 on Mega2560
#define SD_ChipSelectPin 4  //using digital pin 4 on arduino nano 328, can use other pins
#include <TMRpcm.h>           //  also need to include this library...
#include <SPI.h>
TMRpcm tmrpcm;   // create an object for use in this sketch
void setup(){
 tmrpcm.speakerPin = 9; //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
 if (!SD.begin(SD_ChipSelectPin)) {  // see if the card is present and can be initialized:
   Serial.println("SD fail");
   return;   // don't do anything more if not
 tmrpcm.play("Thomas.wav"); //the sound file "music" will play each time the arduino powers up, or is reset
void loop(){
 if(Serial.available()){
   if(Serial.read() == 'p'){ //send the letter p over the serial monitor to start playback
Here are the errors
D:\TMRpcm-master\examples\basic\basic.ino: In function 'void setup()':
D:\TMRpcm-master\examples\basic\basic.ino:19:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
D:\TMRpcm-master\examples\basic\basic.ino: In function 'void loop()':
D:\TMRpcm-master\examples\basic\basic.ino:28:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
I would deeply appreciate any help and advice
el_supremo
#1
Oct 11, 2016, 06:31 pm Last Edit: Oct 11, 2016, 06:32 pm by el_supremo
Those aren't errors, they are warnings - it says so right in the message. A string such as "Thomas.wav" has a default type of "const char *" which means that it can't be changed (read-only) but the play function is presumably declared to require a "char *". You can make the warnings go away by forcing the string to be of type "char *".
Code: [Select]
  tmrpcm.play((char *)"Thomas.wav");
If your code is failing to compile, those two warnings weren't the problem. Look for the error messages.
Pete
Don't send me technical questions via Private Message.
BangmanHackerman
Thanks man appreciate it, that made things clearer. I believe I found the errors
basic:11: error: expected unqualified-id before '.' token
   TMRpcm.speakerPin = 9; //11 on Mega, 9 on Uno, Nano, etc
basic:17: error: expected unqualified-id before '.' token
   } TMRpcm.play((char *)("Thomas.wav"); //the sound file "music" will play each time the arduino powers up, or is reset
exit status 1
Is this right?
el_supremo
Those are indeed errors.
Code: [Select]
You've declared an object of type TMRpcm to have the name tmrpcm. But in your code you refer to it as TMRpcm. Where you have, for example,
Code: [Select]
change it to
Code: [Select]
(Don't change the declaration - it is correct)
Pete
BangmanHackerman
Ok did it
Code: [Select]
#include <pcmConfig.h>
#include <pcmRF.h>
#include <TMRpcm.h>
void setup(){
  tmrpcm.speakerPin = 9; //11 on Mega, 9 on Uno, Nano, etc
  } tmrpcm.play((char *)("Thomas.wav"); //the sound file "music" will play each time the arduino powers up, or is reset
Now this pops up
basic:18: error: expected ')' before ';' token
exit status 1
Btw sorry for relying on you so much, you are in great help.
pjrc
Looks like you've got 3 open parens "(" but only 2 close parens ")".  Try adding another close ")" at the end.
BangmanHackerman
Just tried that, got a lot more problems now....
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp: In member function 'byte TMRpcm::metaInfo(boolean, char*, char*, byte)':
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp:1381:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   char* datStr = "LIST";
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp:1382:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   if(infoType == 1){datStr = "ID3 "; datStr[3] = 3;}
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp:1410:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
  char* tagNames[] = {"INAM","IART","IPRD"};
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp:1430:16: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    tagNames[0] = "TPE1"; tagNames[1] ="TIT2"; tagNames[2] ="TALB";
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp:1430:38: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp:1430:59: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp: In member function 'void TMRpcm::finalizeWavTemplate(char*)':
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp:1568:65: warning: narrowing conversion of '(fSize >> 16)' from 'long unsigned int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
  seek(4); byte data[4] = {lowByte(fSize),highByte(fSize), fSize >> 16,fSize >> 24};
C:\Users\olaba270800\Documents\Arduino\libraries\TMRpcm-master\TMRpcm.cpp:1568:77: warning: narrowing conversion of '(fSize >> 24)' from 'long unsigned int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
C:\Users\OLABA2~1\AppData\Local\Temp\ccOwGiMm.ltrans1.ltrans.o: In function `main':
ccOwGiMm.ltrans1.o:(.text.startup+0x84e): undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
