Topic: analogWrite Arduino DAC1 output like pwm digitalWrite (Read 1 time) previous topic - next topic
wdclot1
I use analogWrite(DAC1,Output) in my code, but I find it like digital pulse output, rather than expected analog continuous curve, i don't know why, forgive a fresh people in C language.
#include<PID_v1.h>
double Setpoint, Input, Output;
PID myPID(&Input,&Output,&Setpoint,2,5,30,DIRECT);
  Input= analogRead(A0);
  Setpoint = 3000;
  myPID.SetMode(AUTOMATIC);
  myPID.SetSampleTime(10);
  Input = analogRead(A0);
  Serial.print("Input = ");
  Serial.println(Input);
  myPID.Compute();
  analogWrite(DAC1,Output);
  Serial.print("Output = ");
  Serial.println(Output);
spycatcher2k
What Arduino do you have? If it's an UNO or MEGA then it does not have a DAC, it uses PWM output. This can be turned to a kind of analog output with a low pass filter.
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
wdclot1
I have  some Arduino Due borads, so there is DAC1 pin
spycatcher2k
Could try adding
  analogWriteResolution(12);  // set the analog output resolution to 12 bit (4096 levels)
  analogReadResolution(12);   // set the analog input resolution to 12 bit
to your setup
Mrs Drew
wdclot1
Sorry, I have tried it just now, but it's not useful, then the output in oscialloscope are very small. A proportion reduce to 255/4096.
vaj4088
I do not have a Due so I cannot comment directly.
The documentation at
https://www.arduino.cc/en/Reference/AnalogWrite
in the third paragraph says
The Arduino Due supports analogWrite() on pins 2 through 13, plus pins DAC0 and DAC1. Unlike the PWM pins, DAC0 and DAC1 are Digital to Analog converters, and act as true analog outputs.
wdclot1
But in my code, the analogWrite(DAC1, Output)still output signal like PWM, some pulses
spycatcher2k
Write a sketch to output 128 to the port in setup, and measure with your oscilloscope to see if the issue stays.
Mrs Drew
dlloyd
Note that the voltage range on the DAC output is 0.55V to 2.75V for 0 to 4095 in code. (1/6 to 5/6 of Vcc)
