Topic: digital switch ? with arduino . how to do it (Read 6975 times) previous topic - next topic
g43q654wutrjh
i have a separate device that has a push button switch.
is there a simple way to use the arduino to trigger the switch?
like a relay or like a transistor or is there a way without?
for example a led torch, the switch is not switching the power to the led only switching (triggering) an IC to turn on the torch.
thanks
CAT6
larryd
#1
Oct 27, 2016, 06:42 pm Last Edit: Oct 27, 2016, 06:44 pm by LarryD
Are you familiar with switches and outputs?
http://www.gammon.com.au/forum/?id=11955
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
g43q654wutrjh
sorry I don't understand what your comment has to do with my question ?
thanks
CAT6
septillion
You have to be more precise. Yes, probably it's possible but what is the best/easiest method we can't tell. The "switch" might be a tiny switch on a remote or a massive 400V 3-phase switch. Both switches, both controllable from the Arduino but the solution is quite different...
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
g43q654wutrjh
pretty sure I covered that in my example
"for example a led torch, the switch is not switching the power to the led only switching (triggering) an IC to turn on the torch."
= LOW POWER  ...yes like a remote.
thanks
CAT6
septillion
#5
Oct 28, 2016, 11:53 am Last Edit: Oct 28, 2016, 11:54 am by septillion
But that still doesn't tell us everything. What does it switch? To GND? To 12V? To 5V? What is the rest voltage etc. Just "low power" doesn't cut it ;)
And you say, for example. But keep in mind another "example" might need a complete different approach.
Grumpy_Mike
The low risk approach is to use the Arduino to turn on a relay and then wire the relay contacts across your switch. That way everything is isolated.
The wiring to do this is shown in LarryD's second diagram which shows a relay being driven from the Arduino through a FET.
septillion
That indeed always works if you choose a relay that can handle the voltage and current.
Cons of that:
-Slow, so you cannot switch it fast
-Probably way over complicated for a lot of cases
g43q654wutrjh
a relay uses to much power need something to keep the power down maybe a transistor but not sure which will be best
CAT6
Grumpy_Mike
How much is too much?
You can get very low power relays you know.
dlloyd
#10
Oct 29, 2016, 03:36 am Last Edit: Oct 29, 2016, 04:40 am by dlloyd
You can loose the diode once you know the polarity for button connections. The "+" terminal connects to the collector, "-" terminal to emitter. Can determine polarity with multimeter (or trial and error).
