Topic: Using the Keypad library with the adafruit 1x4 membrane keypad (Read 3067 times) previous topic - next topic
joekitch
https://www.adafruit.com/product/1332
the keypad library is great and all but it seems build exclusively for matrix keypads, rather than single dimensional keypads
specifically, all the examples have this instantiation
Code: [Select]
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
    {'1','2','3'},
    {'4','5','6'},
    {'7','8','9'},
    {'*','0','#'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
i tried dropping the const rows to 1 and cols to 4 and changing the char to be {'1','2','3','4'}, thinking it's just a matter of making the matrix 1D but that doesn't seem to have any effect, pressing keys doesn't output anything to the serial monitor
is this library just not suited to this and i've be better off doing some input pullup in a loop?
TomGeorge
Can you please post a copy of your sketch, using code tags?
Thanks  Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
joekitch
Thanks  Tom... :)
it's the adafruit 1x4, i linked it
my crappy hacky sketch was just changing the instantiation section to this
Code: [Select]
#include <Keypad.h>
const byte ROWS = 1;
const byte COLS = 4;
    {'1','2','3',4'}
byte rowPins[ROWS] = {}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {9,10,11,12}; //connect to the column pinouts of the keypad
the 4 signal lines of the keypad are in pins 9,10,11,12, with the 5th line being the ground
the full sketch is this, just the customkeypad sketch that comes with the keypad.h library
Code: [Select]
/* @file CustomKeypad.pde
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Demonstrates changing the keypad size and key values.
#include <Keypad.h>
    {'1','2','3',4'}
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );;
void setup(){
void loop(){
  char customKey = customKeypad.getKey();
  if (customKey){
    Serial.println(customKey);
TomGeorge
You need to tell it the row connection, that will be the common to Pin 5, not common to gnd.
Code: [Select]
byte rowPins[ROWS] = {5}; //connect to the row pinouts of the keypad
Try that...  Tom... :)
joekitch
Code: [Select]
there we go, that did it. i just assumed the common would go to ground, wouldn't have thought to put it as the row pin.
The button wiring is strange though. pressing the one key on the membrande keypad outputs the second value (1), two = the first value (0), three is the fourth value (3), and four is the third value (2).
TomGeorge
That is not unusual for membrane switchs as they are limited in how the tracks can run.
You just need to edit the order in the
Code: [Select]
    {'1','2','3',4'}
statement.
Tom... :)
EA3BIL
Sorry for brinnging this item back...
Is it possible to use the Analog pins (A0...A3) instead of 9...12  ??
If so...
Wich way do they need to be declared??:
byte colPins[COLS] = {A0,A1,A2,A3};
OR
byte colPins[COLS] = {14,15,16,17};
NOTE:
Row pin is 13 in my case, so no problem on it.
Thanks,
Rafa.
marco_c
YEs. The analog inputs can be used for digital input. You can declare them either way, no difference.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
