Topic: arduino failure (Read 233 times) previous topic - next topic
Aaakash
can someone tell me what i should do??
when i connect board to the pc it shows status of on and led of pin 13 is on permanently
pert
Nothing you said indicates a problem so go ahead and start having fun with your Arduino! I suggest trying out some of the sketches at File > Examples to get started learning.
sterretje
#2
Nov 04, 2016, 04:10 pm Last Edit: Nov 04, 2016, 04:13 pm by sterretje
That is, after installing the IDE, of course ;)
Usually, the led on pin13 should be blinking at a rate of 0.5 Hz (1 second on, 1 second off) . Try to cpmpile and upload the blink example and check if it works.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
