Topic: connect using an FFC Zif (Read 512 times) previous topic - next topic
ashayk
I'm looking for a little help. I have a sensor with a ribbon that's compatible with an FFC ZIF connector (15 pin, 1.25mm pitch). I need to connect this to an Adafruit Feather 32u4 (will only be connecting 8 pins). Ideally, I don't want to solder to the board, but run this setup through some kind of quick disconnect. So, it might be something like Sensor->FFC ZIF->Male Component (soldered to ZIF)->Female Component (soldered to board). Or some similar variation.
Looking for some guidance regarding what connectors to use and general setup. Any help would be much appreciated.
Thanks,
--Alex
