Topic: 2 digit 7 segment Help (Read 1 time) previous topic - next topic
gregchill
Hi I am trying to get a 2 digit 7 segment to work with 2 shift registers and a button.
I have used the following sketch as a starting point, it works with one register and one digit can anybody point me in the right direction to make a 2 digit display with 2 shift registers to increment 0 - 99 on a  button press.
I have a 2 digit common cathoid 2 digit 7 segment  display.
Any help would be great.
septillion
I have no clue why that guy only lights one bar at a time.... He can just shift out the byte from numbers and be done!
For two segments, just shift out the first, then the second and only then toggle latch :)
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
gregchill
Thanks for the reply.
do i need to create another number int set of (10 numbers.)?
Quote
Not sure how to shift out the second? do you mean.
something like this?
Code: [Select]
digitalWrite(latchPin, LOW);                  // Set latchPin LOW while clocking these 8 bits in to the register
   shiftOut(dataPin, clockPin, LSBFIRST, data);
   digitalWrite(latchPin, HIGH);
original code
Code: [Select]
const int latchPin = 5;  // Pin connected to Pin 12 of 74HC595 (Latch)
const int dataPin  = 6;  // Pin connected to Pin 14 of 74HC595 (Data)
const int clockPin = 7;  // Pin connected to Pin 11 of 74HC595 (Clock)
int upPin = 12;      // pushbutton attached to pin 12
int downPin = 13;      // pushbutton attached to pin 13
int currUpState = 1;   // initialise currUpState as HIGH
int currDownState = 1;   // initialise currDownState as HIGH
int prevUpState = 0;
int prevDownState = 0;
int counter = 0;          // initialise counter as zero
int numbers[10] =  // Describe each digit in terms of display segments  0, 1, 2, 3, 4, 5, 6, 7, 8, 9
    B11111100,
    B01100000,
    B11011010,
    B11110010,
    B01100110,
    B10110110,
    B10111110,
    B11100000,
    B11111110,
    B11100110,
    pinMode(latchPin, OUTPUT);   // set SR pins to output
    pinMode(clockPin, OUTPUT);
    pinMode(dataPin, OUTPUT);
    pinMode(upPin, INPUT);   // sets pin 12 as pushbutton INPUT
    pinMode(downPin, INPUT);   // sets pin 13 as pushbutton INPUT
    currUpState = digitalRead(upPin);
    if (prevUpState != currUpState)             // has the state changed from
    {                                           // HIGH to LOW or vice versa
      prevUpState = currUpState;
      if (currUpState == HIGH)                  // If the button was pressed
        counter++;
  if(counter > 8) counter = 0;      // increment the counter by one
    if(counter > 8)
      counter--;
    show(numbers[counter]); // display the current digit
    currDownState = digitalRead(downPin);
    if (prevDownState != currDownState)         // has the state changed from
      prevDownState = currDownState;
      if (currDownState == HIGH)                // If the button was pressed
        counter--;                             // decrement the counter by one
    if(counter < 0)
      counter++;
  void show( byte number)
    // Use a loop and a bitwise AND to move over each bit that makes up
    // the seven segment display (from left to right, A => G), and check
    // to see if it should be on or not
    for(int j = 0; j <= 7; j++)
      byte toWrite = number & (B10000000 >> j);
      if(!toWrite) {
        continue;
       }                 // If all bits are 0 then no point writing it to the shift register,so break out and
       //move on to next segment.
       shiftIt(toWrite); // Otherwise shift it into the register
 void shiftIt (byte data)
   digitalWrite(latchPin, HIGH);                //set latchPin to high to lock and send data
  // put delay here if you want to see the multiplexing in action!
  //  delay(10);
Wawa
This page (and sub pages) might be interesting.
They use the TPIC6C596, which is the same (coding) as the 74HC595, but with higher voltage/current outputs.
https://www.sparkfun.com/products/13279
Leo..
Grumpy_Mike
Quote
Not sure how to shift out the second? do you mean. something like this?
Yes but send out a different byte of data in the second shift out.
septillion
And
No, the second display needs to display the same 10 digits doesn't it? One the single digits and the other the dozens. Aka, the first "value % 10" and the second "value / 10" :)
PaulRB
Quote
dozens
Only if the OP want to display the number in duodecimal format!
septillion
Haha, you're right! I'll never trust Google again when in doubt about a word :D I just meant the multiples of ten
gregchill
Thanks eveyone
Quote
Do i need to create a new void function in order to do this?
septillion
PaulRB
#10
Nov 17, 2016, 12:03 pm Last Edit: Nov 17, 2016, 12:04 pm by PaulRB
No, you just need to split your 0..99 number into tens and units as septillion described.
septillion
But again, I see no use is sending each bar seperate so the code is a bit weird...
Quick edit (so not perfect) to give you an idea of the weird code....
Code: [Select]
//did some edits to remove the stupid parts...
const byte  latchPin = 5;  // Pin connected to Pin 12 of 74HC595 (Latch)
const byte dataPin  = 6;  // Pin connected to Pin 14 of 74HC595 (Data)
const byte clockPin = 7;  // Pin connected to Pin 11 of 74HC595 (Clock)
const byte upPin = 12;      // pushbutton attached to pin 12
const byte downPin = 13;      // pushbutton attached to pin 13
bool prevUpState = 0;
bool prevDownState = 0;
//Min and max value of the counter
const byte maxCount = 99;
const byte minCount = 0;
byte numberOfDigits = 2;
const byte numbers[10] =  // Describe each digit in terms of display segments  0, 1, 2, 3, 4, 5, 6, 7, 8, 9
  B11111100,
  B01100000,
  B11011010,
  B11110010,
  B01100110,
  B10110110,
  B10111110,
  B11100000,
  B11111110,
  B11100110,
  //counter part
  //currUpState = digitalRead(upPin); <== NO need for stupid global
  if (prevUpState != digitalRead(upPin))             // has the state changed from
    prevUpState = !prevUpState; //invert
    if (currUpState == HIGH && counter < maxCount)                  // If the button was pressed AND not reached limit
      counter++;
    //if (counter > 8) counter = 0;     // increment the counter by one <=== LIMITS IT TO 8 NOW!
  /* useless bit of code
  if (counter > 8)
    counter--;
    if (currDownState == HIGH && counter > minCount)                // If the button was pressed AND not reached limit
  /* weird bit
  if (counter < 0)
    counter++;
  showNumber(counter); // display the current digit
void showNumber(int number)
  /*just a bit weird
  for (int j = 0; j <= 7; j++)
    if (!toWrite) {
      continue;
  digitalWrite(latchPin, LOW);                  // Set latchPin LOW while clocking bits in to the register
  for(byte i = 0; i < numberOfDigits; i++){
    shiftOut(dataPin, clockPin, LSBFIRST, numbers[number % 10]);
    number /= 10;
gregchill
Thanks for explaining that and showing the sample it works great now
Cheers
Greg
DimmyB
Greg, would you mind posting the final code bro?!
Greetings from Brazil!!
