Hello I am in deep need of help, I have a keypad 4x4 matrix as input where as you enter a 4 digit number a certain output follows(water pump in my case), so basically i tried the circuit with a LED and it worked just fine, but without changing anything in the circuit only replacing the LED with the water pump makes the water pump not operate although the water pump operates using the 5v power pin , what makes it not work even though the LED works in the exact same situation in the circuit? Idk how can I draw the circuit for you here but I hope my information is enough, I have stated it worked just fine as I wanted it to work but the difference is that it worked fine using a LED as output but replacing the output without moving any circuit components just literally makes the water pump not work.
PS: It's just that the digital pins seem to not operate it although they output a 5v same as the power pins.
What I use(if it makes any difference):
4x4 matrix keypad
Arduino UNO
5v water pump
