Topic: void loop(void) vs void loop() (Read 5633 times) previous topic - next topic
Gabriel_swe
Usually code is only
but sometimes I see code that use void inside the parenthesis
void setup(void)
void loop(void)
With my limited C knowledge I can't see there is any difference. Am I right in my assumption?
Delta_G
There is no difference at all.  With an empty set of parenthesis the function is assumed to take nothing (ie void) as an argument.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
Arduino_n00b
Ugh...
It's for reasons like this that noobs such as myself get confused, misled, and even made fun of. >:(
Here's an example that should be updated or down-dated: ;D
#include <Wire.h>
#include <Adafruit_MCP4725.h>
#define voltsIn A0
Adafruit_MCP4725 dac; // constructor
void setup(void) {
  dac.begin(0x60); // The I2C Address: Run the I2C Scanner if you're not sure
void loop(void) {
    uint32_t dac_value;
    int adcValueRead = 0;
    float voltageRead = 0;
    float dac_expected_output;
    for (dac_value = 0; dac_value < 4096; dac_value = dac_value + 15)
      dac_expected_output = (5.0/4096.0) * dac_value;
      dac.setVoltage(dac_value, false);
      delay(250);
      adcValueRead = analogRead(voltsIn);
      voltageRead = (adcValueRead * 5.0 )/ 1024.0;
      Serial.print("DAC Value: ");
      Serial.print(dac_value);
      Serial.print("\tExpected Voltage: ");
      Serial.print(dac_expected_output,3);
      Serial.print("\tArduino ADC Value: ");
      Serial.print(adcValueRead);
      Serial.print("\tArduino Voltage: ");
      Serial.println(voltageRead,3);
The void loop(void) thing should have been tossed out like the BYTE function!
Better yet, keep the void loop(void) fallacy and bring back the BYTE function.
Please don't bite.  :smiley-mr-green:
I'm not an A.I. Avatar yet.
lastchancename
Just like architectural drawings... VOID is a placeholder for NOTHING, or EMPTY
Wherever you see the word void, don't put, or go looking for *anything*, because it won't be there!
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
PerryBebbington
You have my sympathy with this one. I was taught C by 2 very good friends and agonised over the difference between
void function();
and
void function(void);
I guess it was so obvious to my friends that they are the same they didn't see any reason to tell me! I wasted a lot of time trying to work out how they were different.
slipstick
Some people like being able to do a thing in several different ways.
Some people seem to take that ability as a personal affront intended solely to confuse them.
Once you've recognised that void is a just a way of explicitly saying "You can look away now, there's definitely nothing here" it's pretty obvious (as many things are...after you've learned them!).
Steve
noob314
#6
Dec 06, 2019, 11:20 am Last Edit: Dec 06, 2019, 01:59 pm by noob314
There is several standard revisions for C and C++, but I do not think there is a specific requirement for this case. I believe it is stay the same from initial Kernighan and Ritchie's C definition - both versions are acceptable.
UKHeliBob
It sounds like you have met my wife !
