Topic: PLX-DAQ version 2 - now with 64 bit support! (and further new features) (Read 183549 times) previous topic - next topic
adwsystems
Nononono, I wasn't trying to be sarcastic to you, I tried to suggest a GitHub repo be made for this software in previous posts to no avail. Sorry for the confusion
My apologies as well. It is a great idea.
NetDevil
Hi there
@adwsystems: each post links back to the initial post where I have provided and overview of all available versions including links to the posts for downloading. The important part is, that it is "version two point eleven" (2.11) thus it is more recent then 2.2 and 2.3  :) it is the most recent one  :)
@Power_Broker: yeah ok, go ahead. Sorry to say but my life consists of things apart caring for this thread like my job, the house I recently build, my leisure time, quality time with my wife and yeah by the way we are expecting a baby. So sarcastic some one else or go for it yourself. Isn't that the whole point of Free and Open Source Software... Never had anyone complained about a version control here except you. Thanks.
abhiramnvs
I am able to save data in an excel sheet but if I want to read data from an excel sheet through arduino and send it through zigbee protocol.. how can it be done?
NetDevil
Hi ahiramnvs,
since you're already able to store/send data to Excel you have achieved more then half the way already  ;) Please take a look at the Beginners Guide, there is a section with regards to the "CELL,GET" command. It allows Arduino to query the content of a specific cell from Excel.
On Arduino side it is important to do two steps: 1) query the data via CELL,GET command and 2) wait for the data to be received (code is in the document).
Afterwards you can process the received data and continue to send via zigbee protocol. Regarding that zigbee, I know basically what it is but never had any experience on it. So from there on I can't help you with that.
Cheers
abhiramnvs
How do I get/read a complete  row or a column in arduino. Till now I'm able to access only a single value from a row by using CELL,GET but hoe do we get a complete row??
NetDevil
Hi, there is no function for this.
There never was an actual demand and basically no need because all data in Excel comes from Arduino - so why first write to Excel and then query back? Better to store it directly in Arduino.
You could write it yourself but it comes with some tricky questions (like which data format to use).
Or in case you know the number of lines/columns you could use CELL,GET in an iteration (not really performant).
abhiramnvs
can you help me how to use CELL,GET in an iteration if I have 20values in a single row A.
for(i=0;i<=20;i++)
Serial.println("CELL,GET,A%d",n); or Serial.println("CELL,GET,An"); or some thing likw this? Help please
adwsystems
@adwsystems: you are right, there is only that one option to send data from PLX DAQ to Arduino. I haven't had any other use case ; yet. Attached you can find a special version of 2.11 with a new text field to send data to Arduino (please expand DirectDebugWindow to fully see the field + button + label). It only works while being connected (obviously  :D ). Give it a try and I might add the same (in beautiful) to the next release. I might add two or three text fields at the same time thus one can post different pre-defined commands more rapidly.
I know I'm hoping in the way back machine to post #128. But that is where I need the assistance. I'm finally trying to finish that project.
I am working to make a kind-of SD DOS (just the basic commands) that will appear in the debug window. The point here is to be able to see the files on the card while connected to the Arduino without interrupting the Arduino or having to disassemble the system to remove the card and attach it to the computer to just find the file name. Once the filename is determined, a command will be given to transfer it using the standard PLX-DAQ and into the excel file.
I had my SD DOS working in the serial monitor with sending a carriage return (char(13)). The PLX-DAQ write window (ref v2.11 special in post 128) doesn't appear to send char(13). That's fine. In the spirit of C programming, I included the semi-colon as a substitute for char(13). Here's the issue. Via PLX-DAQ, the first command works fine, the second and on does not. It works fine through the serial monitor (either with carriage return and no semi-colon, or semi-colon and no carriage return).
My assumption is there is an additional item sent from the PLX-DAQ that is not from the serial monitor and thus the command buffer is being thrown off. I am in need of help to confirm this and develop a pathforward (or correction to my Arduino program; attached).
TIA @NetDevil.
adwsystems
TIA @NetDevil.
Nevermind. The answer is newline (char(10)).
NetDevil
Hi abhiramnvs,
for(i=0;i<=20;i++)
better use the [ code ] function of this board when posting source code in order to make it more readable.
From the top of my head and according to what I have written in the Beginners Guide it should look something like this to read 20 Integer values from A1 to A20:
for ( int i = 1 ; i++ ; i<=20; ) {
   Serial.println( (String) "CELL,GET,A" + i);
   myValue = Serial.readStringUntil(10).toInt();
   Serial.println( (String) "Read value is: " + myValue);
Hi adwsystems,
and sorry for not getting back to you earlier. Anyways it looks like you have proven some dedication and figured out the solution yourself already :) nice job!
Yeah, as shown in the code above for abhiramnvs, the "End of Line" character used is char(10). char(13) is also common, as a combination of both. But for some reason back then I chose char(10) as I might recall it was the more commonly use one.
In case of any further questions please feel free to ask :)
Cheers to both of you.
JGreenB
Just wanted to thank the creators and updaters!
Works like a charm in my system  :)
