Topic: Arduino Controlled Automotive Light Control with BT (Read 1 time) previous topic - next topic
ClncyFshSlayer
So, project background first. I am in the process of designing a PCB that incorporates a microcontroller, LEDs, capacitive sensors and relays to control auxiliary light in my truck. I have the little stuff worked out and have it prototyped and working, but I want some outside input on the relays on the board.
The relays are 30/40A Bosch Style (5 pin) automotive relays. They are triggered by the microcontroller when it receives a certain input.
I want to make sure that I have adequate trace widths to support the relays when an auxiliary component is triggered. Right now I plan to use 1 oz copper for the board when I have it printed (trace width is 150 mil on the relays and power). I have attached the PCB design to this post.
Each individual relay would have a max of 30A @ 12V on it, and all power lines on the board are fuse protected. In all reality, it is likely that only one relay would be on at a time, and only a single relay will need to support the 30A load, the other relays will only need to handle a couple of amps.
I am new to incorporating microcontrollers and higher amp 12v loads in to a PCB, so I may be approaching this completely wrong. Any input is greatly appreciated!
