Topic: WS2812B LEDs, help! (Read 572 times) previous topic - next topic
Twined
Im currently making a matrix, 4x2. But when I cut the strip at the point an solder with a bit of wire between, the next strip doesn't light up. There is currency running thru, but there is no light! I don't know why this happening! Please help!
Code:
http://hastebin.com/hijiliwako.cpp
Grumpy_Mike
Quote
Because you have not done it correctly, if you did then it would work.
However we have no information about what you actually did, only what you thought you did. So you could have misidentified the wires or have bad soldered joints for a start. A schematic and a ( good ) photograph would clear things up.
Quote
What sort of currency, Dollars, Sterling, Euros or what?
Kevin77
lol Devil you...
Grumpy_Mike
Please read the how to use this forum sticky post and then post your picture so that everyone can see it.
There is no way I am downloading a zip file from a URL without a name. Also iPads don't handle zip files anyway.
