I need to Hash a value that is set to a server over ethernet. After looking I am not certain what Hash functions are available. Does anyone know if there are any standard hash functions like MD5 or SHA for the arduino?
Why? Can you explain what you are trying to do? I don't think that generating a hash value is the answer.
I am trying to have the arduino send a message to the server and was planning on hashing the UUID, password and a timestamp in order to act as a one time password on the server. In otherwords once the hash is used to authenticate once the server will not accept it again.
I guess it's a matter of semantics. Generally a hash value is used to partition data in a hash table that contains pointers to where data is really stored, in the case where there is a large amount of data, with no reasonable way to sort the data (because the volume of data is too large to move using a traditional sort).
So, I don't think that a hash value is what you want, but, I understand your desire. Unfortunately, I have no idea how to help you.
So I take it that there are no functions that provide an MD5Sum or any other hash algorithms available on the arduino?
Are you trying to generate a "nonce"?
Not that I know of in arduino, google around for C / avr-asm implementations of various hashes, they're around.
XTEA encrypt is only 6 lines long, if low security is fine:
Assuming 16char limit on passwd, encrypt concatenation of 32bit UID and 32bit time using the zero padded passwd as the key.
There is an awesome c implementation on sha-1 somewhere on the web, Google it. I used it for my nintendo DS a while ago.
However it it possible that sha-1 is a bit to advanced and power consuming i guess. I would just make my own hash function, as it is fairly easy. Unless you require bank security.
Here's a crypto library for AVR microcontrollers: AVR-Crypto-Lib/en – LaborWiki
(FWIW, that was the 3rd hit on google using 'AVR SHA-1' - there are tons more. This does not seem novel.)
!c
I get what you are trying to do.
I modified the AVR-Crypto MD5 implementation so that it can be used as a library.
