Met een gewoon if statement kom je er niet mee weg. Er is als het goed is in de library een voorbeeld om de Uid te veranderen. dit is de sketch:
* Example to change UID of changeable MIFARE card.
* This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
* This sample shows how to set the UID on a UID changeable MIFARE card.
* NOTE: for more informations read the README.rst
* @author Tom Clement
* @license Released into the public domain.
* Typical pin layout used:
* MFRC522 Arduino Arduino Arduino Arduino Arduino
* Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro
* Signal Pin Pin Pin Pin Pin Pin
* RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
* SPI SS SDA(SS) 10 53 D10 10 10
* SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
* SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
* SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
/* Set your new UID here! */
#define NEW_UID {0xDE, 0xAD, 0xBE, 0xEF}
MFRC522::MIFARE_Key key;
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Warning: this example overwrites the UID of your UID changeable card, use with care!"));
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
// Setting the UID can be as simple as this:
//void loop() {
// byte newUid[] = NEW_UID;
// if ( mfrc522.MIFARE_SetUid(newUid, (byte)4, true) ) {
// Serial.println("Wrote new UID to card.");
// delay(1000);
// But of course this is a more proper approach
// Look for new cards, and select one if present
if ( ! mfrc522.PICC_IsNewCardPresent() || ! mfrc522.PICC_ReadCardSerial() ) {
delay(50);
return;
// Now a card is selected. The UID and SAK is in mfrc522.uid.
// Dump UID
Serial.print(F("Card UID:"));
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
Serial.println();
// Dump PICC type
// MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
// Serial.print(F("PICC type: "));
// Serial.print(mfrc522.PICC_GetTypeName(piccType));
// Serial.print(F(" (SAK "));
// Serial.print(mfrc522.uid.sak);
// Serial.print(")\r\n");
// if ( piccType != MFRC522::PICC_TYPE_MIFARE_MINI
// && piccType != MFRC522::PICC_TYPE_MIFARE_1K
// && piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
// Serial.println(F("This sample only works with MIFARE Classic cards."));
// return;
// Set new UID
Serial.println(F("Wrote new UID to card."));
// Halt PICC and re-select it so DumpToSerial doesn't get confused
mfrc522.PICC_HaltA();
return;
// Dump the new memory contents
Serial.println(F("New UID and contents:"));
mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
delay(2000);
Daarvan is dus dit stukje code van belang
// Dump UID
Serial.println();
Dit print de Uid uit. Je zult dus een array moeten maken waarin de Uid staat die je wilt testen. Dan een boolean vooraf zetten op bijv.
boolean gevonden = true;
Dan vergelijk je de gelezen Uid met de Uid die je in het geheugen hebt en zodra er een byte een verschil heeft zet je gevonden op false en doe je een break; verder zoeken in de loop is weinig zinvol omdat hij toch al ongelijk is.
