So I'm trying to get the average temperature, I already tried the 'Smoothing' tutorial with digitalRead instead of analogRead, but it only prints '0' and '1', not the average temperatures haha.
Currently only working with seconds (delay of 1000), but at the end I'll calculate the average of 15 minutes (where the sensor measures every 1 mintute).
// read from the sensor:
readings[readIndex] = digitalRead(2);
You aren't reading the temperature from the sensor. You are reading the state of the digital pin to which the sensor is connected - not the same thing at all.
There are any number of examples on this forum of how to read the temperature using the Dallas Temperature library. Search.
Just to clarify. Are you using a DS18B20 or other sensor that the Dallas library is designed to work with?
First of all, you are reading your temperature sensor wrong. A simply digitalRead of a pin will only give you a LOW or HIGH (that is, only a 0 or a 1).
For averaging, try this:
// these are OUTSIDE the functions to be public accessable
double accumulator = 0.0;
uint32_t readings = 0;
double collect_data (double value)
accumulator += value; // add to accumulator
readings++; // increment count
return (accumulator / readings); // return current average
This will accept any number of readings (up to 4 billion!) and return the average whenever you want it.
You can even read the CURRENT average, then let it keep running and read ANOTHER average LATER.
Krupski:
Hope this helps.
So, I add the double accumulator and uint32_t above my void setup, and the double collect_data below my loop. So, what should I put in my loop to do this?
I'm sorry, little bit noob with Arduino coding haha.
BTW, my sensor is a Dallas DS18B20. So as seen in my original code, I can print the temperature with: Serial.print(sensors.getTempCByIndex(0)); //
MichaelW1998:
Yes, that's how you would get (and print) the temperature value (in degC) from the DS18B20. But, that's not what you're doing in the original code that you posted. As pointed out by @el_supremo, you're simply reading a DIGITAL value from DIGITAL PIN 2. The only possible results are 1 or 0. I'd concentrate on getting the right temperature reading first before worrying about averaging.
gfvalvo:
Yes I got it to print and show the temperature reading. I even got it to print 2 readings with 2 sensors, on the same pin (with one_wire).
But I still have the same question:
Averaging an array of readings has the disadvantage of using up RAM for the array, and having to
sum all the values everytime (though there are tricks to finesse that).
There's a much simpler way to low-pass filter an incoming value by using a simple
digital filter with a single value as state.
float average ;
#define k 0.1 // the filter coefficient, 0.1 means a scale of 10 samples, 0.01 would be 100 samples
void loop ()
float reading = ???? ; // whatever code reads the current value
average += k * (reading - average) ; // simple 1st order digital low pass filter
delay (10) ; // sample rate set by a delay
If you want to average N values everytime you read the sensor, there's no need
to store them:
float take_averaged_reading ()
float sum = 0.0 ;
for (byte i = 0 ; i < N ; i++)
sum += ???? ; // whatever code reads the sensor
return sum / N ;
After 10 reads - very stable median values for DS18B20 with ESP8266 Web Server
Data wire is connected to GPIO 2
Show one decimal in the web server (see attach)
EXAMPLE: // tempC+/-x.xx calibration value =+0.50 celsius
// tempF+/-x.xx calibration value =+0,82 fahrenheit
04:14:49.453 ->
04:14:49.487 -> Connecting to WiFi
04:14:49.977 -> ..
04:14:50.485 -> 192.168.0.106
04:14:51.241 -> Temperature Celsius: 20.79
04:14:51.309 -> Temperature Fahrenheit: 69.46
04:14:51.377 -> Temperature Celsius: 20.78
04:14:51.445 -> Temperature Fahrenheit: 69.45
04:14:51.648 -> Temperature Celsius: 20.77
04:14:51.716 -> Temperature Fahrenheit: 69.44
04:15:02.128 -> Temperature Celsius: 20.77
04:15:02.162 -> Temperature Fahrenheit: 69.43
04:15:12.127 -> Temperature Celsius: 20.76
04:15:12.161 -> Temperature Fahrenheit: 69.42
04:15:14.099 -> Temperature Celsius: 20.76
04:15:14.133 -> Temperature Fahrenheit: 69.41
04:15:19.505 -> Temperature Celsius: 20.74
04:15:19.539 -> Temperature Fahrenheit: 69.41
04:15:24.972 -> Temperature Celsius: 20.74
04:15:25.006 -> Temperature Fahrenheit: 69.40
04:15:35.167 -> Temperature Celsius: 20.73
04:15:35.201 -> Temperature Fahrenheit: 69.40
04:15:41.778 -> Temperature Celsius: 20.73
04:15:41.812 -> Temperature Fahrenheit: 69.36
04:15:52.029 -> Temperature Celsius: 20.74
04:15:52.064 -> Temperature Fahrenheit: 69.36
04:15:54.678 -> Temperature Celsius: 20.74
04:15:54.745 -> Temperature Fahrenheit: 69.36
04:16:04.870 -> Temperature Celsius: 20.73
04:16:04.904 -> Temperature Fahrenheit: 69.37
04:16:14.859 -> Temperature Celsius: 20.73
04:16:14.927 -> Temperature Fahrenheit: 69.35
04:16:24.869 -> Temperature Celsius: 20.73
