Hi there,
So I'm trying to get the average temperature, I already tried the 'Smoothing' tutorial with digitalRead instead of analogRead, but it only prints '0' and '1', not the average temperatures haha.
This currently is my code:
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
// start serial port
Serial.println("Temperatuur sensor by MAIĀ©: 1min");
// Start up the library
sensors.begin();
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
// subtract the last reading:
total = total - readings[readIndex];
// read from the sensor:
readings[readIndex] = digitalRead(2);
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
Serial.println(average);
delay(1000); // delay in between reads for stability
Currently only working with seconds (delay of 1000), but at the end I'll calculate the average of 15 minutes (where the sensor measures every 1 mintute).
Thanks!
