Topic: L298N H Bridge wired wrong (Read 495 times) previous topic - next topic
skindova
Hi!
I've been working on a project in which i need to control 2 motors. Therefore, i bought a ln298n h bridge. After i wired everything and it wasn't working, i noticed i connected the wires wrong (9V from the battery connected to H-Bridge Gnd and battery Gnd to H-Bridge 12v). Even after i fixed that, the Bridge does not seem to be working (Voltage on the motor output is always 0v). Is it possible that the H-Bridge is damaged because i switched the polarity, or am i doing something else wrong?
Thanks so much!
MarkT
Yes it is very possible you have damaged it.
When you say 9V is that a small 9V battery of the sort that cannot provide enough current
to power motors?  Have you tried a decent supply instead? For 2 motors you are likely to need
several amps fom the supply.
If you are lucky the weakness of small 9V batteries in providing current may have reduced/prevented
damage to the H-bridge chip, and nothing works because the battery is too weak.  Or you may be
unlucky and have let the magic smoke out...
skindova
Thanks for the help!
It is actually a 12V battery, but it has only 9.something V because i havn't recharged it for a while...
How can i test if the bridge is ok then?
thanks
jremington
#3
Dec 11, 2016, 04:10 am Last Edit: Dec 11, 2016, 04:10 am by jremington
Wire it correctly and test it with a good power supply. If it smokes, it is dead.
MarkT
A 12V lead-acid battery that reads 9V is irreparably damaged.  10.5V minimum voltage is about it,
and then only if you immediately recharge.
