Topic: Problem on Project 3 Love-O-Meter (Read 1 time) previous topic - next topic
Hatred_Realm
Dec 15, 2016, 02:21 am Last Edit: Dec 15, 2016, 02:35 am by Hatred_Realm Reason: Using quote instead code to put a code
Hello.
I'm new to arduino and electronic.
I was doing a project 3 Love-O-Meter and expanded the project from 3 LED to 6 LED.
3 Red LED is to measure the hot environment and 3 Blue Led is to measure the cold environment.
But, i am facing a problems during this project and i would like to ask a few question.
My question is :
1. Why the temperature shown in the serial monitor is sometimes unstable ?
But when i touch the sensor, the temperature increase and it become stable.
2. Why the temperature shown the in serial monitor changed drastically when i shake or move the breadboard or arduino for a few cm ?
3. Is the code i write to measure the cold environment is the simplest one or are there more simplest than this ?
Code: [Select]
const int sensorPin = A0;
const float baselineTemp = 27.0;
  for(int pinNumber = 2; pinNumber < 8; pinNumber ++)
    pinMode(pinNumber, OUTPUT);
    digitalWrite(pinNumber, LOW);
  int sensorVal = analogRead(sensorPin);
  Serial.print("Sensor Value : ");
  Serial.print(sensorVal);
  float voltage = (sensorVal/1024.0)*5.0;
  Serial.print("Volts : ");
  Serial.print(voltage);
  Serial.print("Degrees C : ");
  float temperature = (voltage-.5)*100;
  Serial.println(temperature);
  if(temperature >= baselineTemp+2 && temperature < baselineTemp+4)
    digitalWrite(2, HIGH);
    digitalWrite(3, LOW);
    digitalWrite(4, LOW);
    digitalWrite(5, LOW);
    digitalWrite(6, LOW);
    digitalWrite(7, LOW);
  else if(temperature >= baselineTemp+4 && temperature < baselineTemp+6)
    digitalWrite(3, HIGH);
  else if(temperature >= baselineTemp+6)
    digitalWrite(4, HIGH);
  else if (temperature < baselineTemp && temperature >= baselineTemp-2)
    digitalWrite(2, LOW);
    digitalWrite(5, HIGH);
  else if (temperature < baselineTemp-2 && temperature >= baselineTemp-4)
    digitalWrite(6, HIGH);
  else if (temperature < baselineTemp-4)
    digitalWrite(7, HIGH);
  delay(1);
Thank you very much.
