Topic: multiple voltages from single power supply? (Read 1 time) previous topic - next topic
larryd
"Yes there is, but there's also tutorials for doing brain surgery in your garage, over-unity power generation, making laser guns, anti-gravity......"
How difficult is it to read a few paragraphs to see if a document is beyond you?
60 seconds?  ;)
A person should be able to put some effort into their own education.
When you don't understand something you can ask for assistance.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Pertrucci
I've been using the "filetype:pdf" a lot in Google. ☺
But a lot of books seems good and understandable at first, and then many pages in, I think to myself "wtf am I reading?"
polymorph
Good point, if you are using the signal before and after to drive 2 amps/speakers.
Info on using Op Amps on a single supply voltage:
http://www.ti.com/lit/an/sloa030a/sloa030a.pdf
http://www.analog.com/en/analog-dialogue/articles/avoiding-op-amp-instability-problems.html
http://www.ti.com/lit/an/sboa059/sboa059.pdf
https://www.ieee.li/pdf/essay/single_supply_op_amp_design.pdf
These are from manufacturers, not from someone's ill-thought-out Instructable.
Again- every unused section MUST be properly connected. Do NOT leave inputs floating. Follow proper procedure.
BTW, you can always invert the signal in software to compensate for an inverting preamp.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
