Windows 10 and the newest Arduino 1.6.13 (avrdude.conf copied to the bin directory to avoid using -C parameter).
I want to program an ATmega328P chip using Arduino Uno. I have an IC that is most likely in the default factory configuration (there is a slight chance it was used or is bricked, but I think it doesn't matter for the problem I am facing now). I have connected everything according to the bottom left image here: https://www.arduino.cc/en/Tutorial/ArduinoISP. I have opened ArduinoISP project, compiled it, uploaded - everything went fine. Then I tried to run avrdude just to check if everything is OK:
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -c arduino -p m328p -P COM6 -b 115200 -v
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
Device signature looks OK, fuses look strange - no idea why, first problem. But, 115200 is too fast for programming the chip, the recommended baud rate is 19200. So I modified the code, recompiled it, uploaded (again everything goes OK), tried to run avrdude again with a lower baudrate:
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -c arduino -p m328p -P COM6 -b 19200 -v
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.conf"
Using Port : COM6
Overriding Baud Rate : 19200
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x0fffff
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
Not only the device signature is now off, also some of the parameters listed by the avrdude have changed. It is my understanding that the baud rate is just for the PC<->Arduino communication and doesn't matter for the Arduino<->programmed processor communication, so the result of just reading the data should give the same result. Yet that's not the case. Also, if the processor was bricked I would expect the device signature to be off in both cases - but it looks OK when I am using 115200.
What am I missing? What to check?
