Topic: sysTickHook (Read 704 times) previous topic - next topic
weird_dave
I can't seem to get sysTickHook() to work.
The code below never prints "Tick". Google suggests I need to wrap extern "C"{} around the function, but that gives me a compile error stating that the function is already defined.
Code: [Select]
int hooktimer = 1000;
  Serial.begin(250000);
int sysTickHook(void)
  if (--hooktimer == 0) {
    Serial.println("Tick");
    hooktimer = 1000;
  return 0;
It appears I may not be the only one with this problem:
https://forum.arduino.cc/index.php?topic=380196.0
phr3ak
The original SysTick_Handler from cortex_handlers.c is overdefined in Arduino15\packages\arduino\hardware\sam\1.6.7\cores\arduino\main.cpp and it does not take care about sysTickHook
MustafaAlotbah
It is already defined before, but a weak definition "__attribute__((weak))", you can redefine it with your own code in C.
".ino" extensions are treated like C++ where you can't redefine those functions. The approach for that is by using C language inside as follows
Code: [Select]
#ifdef __cplusplus
extern "C" {
#endif
// C code
int sysTickHook() {
           // your code
// more C code
#ifdef __cplusplus
#endif
