Topic: IDE 1.8.0 Released -- update: 1.8.10 (Read 168178 times) previous topic - next topic
dsyleixa
#270
Mar 11, 2019, 02:05 pm Last Edit: Mar 11, 2019, 02:05 pm by dsyleixa
I have not been following this discussion but that made me giggle
what is funny about that?
hidden folders usualy are not visible by default, but by checking the filemgr option "show also hidden folders" they can be made visible.
But back to the topic:
Quote
thank you, I can't remember how I once installed Arduino IDE on my Pi or if I altered a prior installation,  I once followed some instructions I found in the web (which I do not remember exactly).
Anyway, there is no hidden folder visible.
Is there meanwhile a working apt-get install version?
or just these commands I found here in this forum?
wget http://downloads.arduino.cc/arduino-1.8.8-linuxarm.tar.xz
tar -x -f arduino-1.8.8-linuxarm.tar.xz
will that install automatically also the hidden folder?
if yes, can it be simply deleted, or do I have to change entries in preferences as well?
After that I assume that I'll just have to copy my old portable folde into the new 1.8.8 folder like for Windows,  correct?
UKHeliBob
Quote
Because by definition a hidden folder is not visible.  There may well be a way to make it visible but then, of course, it is not hidden is it ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
dsyleixa
#272
Mar 11, 2019, 02:34 pm Last Edit: Mar 18, 2019, 11:35 am by dsyleixa
that is utterly nonsense and quibbling. Hidden is != Invisible, hidden is like "obscured". A hidden folder is not visible by default file manager display settings, but can be shown up by optional display settings.
back to topic:
Quote
pert
No. Please don't use a package manager to install the Arduino IDE. You will end up with an outdated IDE version that may have been modified in unspecified ways by a 3rd party.
No. The hidden folder is created the first time you start the Arduino IDE without the "portable" subfolder. If you install the Arduino IDE with the above commands, and then create the "portable" before the first time you run the Arduino IDE, the hidden folder will never be created (because the portable folder is used instead).
Correct.
dsyleixa
#274
Mar 11, 2019, 06:24 pm Last Edit: Mar 14, 2019, 09:44 am by dsyleixa
thank you, it works fine now!
(edit: just the location of the Sketch folder had to be added manually to the preferences)
pert
You're welcome. I'm glad if I was able to be of assistance. Enjoy!
Per
oqibidipo
ARDUINO 1.8.9 2019.03.15
[ide]
* New target! ARM64 boards are now fully supported (Nvidia Jetson and RaspberryPi3 with 64bit operating system)
* Fix UTF8 related bugs on Windows
* Fixed: can now compile again using OpenJDK (removed dependency on JavaFx)
* Fixed: only use touchBar on OSX 10.12 or higher
* PluggableDiscovery: easily add your own discoverer and make it available in Boards/Port menu (thanks @PaulStoffregen for the idea and the initial implementation)
* LibManager: reduce slowdown when searching
* Fixed: ensure a sketch line is visible when it contains an error and must be highlighted
* Linux: the installer now tries to install a symlink is /usr/local/bin (this doesn't affect usual non-systemwide installation) Thanks @2E0PGS
[wifi-updater]
* Fix firmware upgrade not being available for 3rd party WINC boards
[arduino-builder]
* Use lexicographic distance as last chance to spot the right library (if every other tecnique failed)
* Fix some prototypes being inserted in the middle of a function
dsyleixa
having installed IDE 1.8.8., the IDE always starts with a new (empty) file, not with the latest working file as before (1.8.5).
How can I make 1.8.8 to automatically load the latest opened file again?
ShermanP
What works for me in 1.8.8 is with the latest working file loaded, click on File -> Quit.  Then it comes back to there when the IDE runs next time.
pert
This is a known issue with Arduino IDE 1.8.8. Luckily, the bug has already been fixed and there is a new IDE version now 1.8.9. Please update to Arduino IDE 1.8.9.
dsyleixa
thanks @all,
to have to reinstall a new version anew is too cumbersome to me, but ctrl+Q for Quit (instead of ALT+F4) is fine!
OTOH, if there was a new Search and a Replace function in the 1.8.9 Editor with find-whole-words-only-option available, then it might be worth-while to upgrade ;)
Southerner
Is there an issue with IDE 1.8.9?  I downloaded and installed it a few days ago.  Today I tried to use it but everything returns a "Error compiling for Arduino/Genuino Uno" and Board Info says it is a Arduino/Genuino Uno and it is on port Com6.  This is using a Windows 7 desktop.  Even the ArduinoISP example sketch returns that same error.  I am unable to do anything with it.  Did I miss something?  I will re download it and reinstall it but this threw me since the previous version I had installed did not have a problem with these boards.
Thank you.
pert
Thank you.
Please do this:
  • When you encounter an error, you'll see a button on the right side of the orange bar "Copy error messages" in the Arduino IDE (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button..
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the error between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
If the text exceeds the forum's 9000 character limit, save it to a .txt file and post it as an attachment. If you click the "Reply" button here, you will see an "Attachments and other settings" link.
modry_salamander
AVG reports that the windows installer contains win32/heim !!!!!!
Please clean it!
MAS3
#284
Apr 04, 2019, 11:06 pm Last Edit: Apr 04, 2019, 11:07 pm by MAS3
It does not contain any problem, according to AVAST's report.
Are you sure you got it from this link: https://www.arduino.cc/download_handler.php?f=/arduino-1.8.9-windows.exe ?
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
