after update 1.8.8 -> 1.8.9
Arduino IDE (Linux Mint)
sketch Blink
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean,
http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/***/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 9600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See
http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
And Sketch -> Upload Using Programmer:
Arduino: 1.8.9 (Linux), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
/home/***/ARDUINO/arduino-1.8.9/arduino-builder -dump-prefs -logger=machine -hardware /home/***/ARDUINO/arduino-1.8.9/hardware -tools /home/***/ARDUINO/arduino-1.8.9/tools-builder -tools /home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -built-in-libraries /home/***/ARDUINO/arduino-1.8.9/libraries -libraries /home/***/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10809 -build-path /tmp/arduino_build_877312 -warnings=all -build-cache /tmp/arduino_cache_4918 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -verbose /tmp/arduino_modified_sketch_862434/Blink.ino
/home/***/ARDUINO/arduino-1.8.9/arduino-builder -compile -logger=machine -hardware /home/***/ARDUINO/arduino-1.8.9/hardware -tools /home/***/ARDUINO/arduino-1.8.9/tools-builder -tools /home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -built-in-libraries /home/***/ARDUINO/arduino-1.8.9/libraries -libraries /home/***/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10809 -build-path /tmp/arduino_build_877312 -warnings=all -build-cache /tmp/arduino_cache_4918 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -verbose /tmp/arduino_modified_sketch_862434/Blink.ino
Using board 'nano' from platform in folder: /home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr
Using core 'arduino' from platform in folder: /home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr
Detecting libraries used...
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_877312/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_877312/sketch/Blink.ino.cpp -o /tmp/arduino_build_877312/preproc/ctags_target_for_gcc_minus_e.cpp
/home/***/ARDUINO/arduino-1.8.9/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_877312/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_877312/sketch/Blink.ino.cpp -o /tmp/arduino_build_877312/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/arduino_cache_4918/core/core_arduino_avr_nano_cpu_atmega328old_a687f7defd46b41b409db8a8fe16211a.a
Linking everything together...
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_877312/Blink.ino.elf /tmp/arduino_build_877312/sketch/Blink.ino.cpp.o /tmp/arduino_build_877312/../arduino_cache_4918/core/core_arduino_avr_nano_cpu_atmega328old_a687f7defd46b41b409db8a8fe16211a.a -L/tmp/arduino_build_877312 -lm
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_877312/Blink.ino.elf /tmp/arduino_build_877312/Blink.ino.eep
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_877312/Blink.ino.elf /tmp/arduino_build_877312/Blink.ino.hex
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_877312/Blink.ino.elf
Sketch uses 930 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avrdude -C/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v2 -Pusb -Uflash:w:/tmp/arduino_build_877312/Blink.ino.hex:i
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
An error occurred while uploading the sketch
