Topic: IDE 1.8.0 Released -- update: 1.8.10 (Read 163410 times) previous topic - next topic
4eburashk
after update 1.8.8 -> 1.8.9
Arduino IDE (Linux Mint)
sketch Blink
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/home/***/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 9600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
And Sketch -> Upload Using Programmer:
Arduino: 1.8.9 (Linux), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
/home/***/ARDUINO/arduino-1.8.9/arduino-builder -dump-prefs -logger=machine -hardware /home/***/ARDUINO/arduino-1.8.9/hardware -tools /home/***/ARDUINO/arduino-1.8.9/tools-builder -tools /home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -built-in-libraries /home/***/ARDUINO/arduino-1.8.9/libraries -libraries /home/***/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10809 -build-path /tmp/arduino_build_877312 -warnings=all -build-cache /tmp/arduino_cache_4918 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -verbose /tmp/arduino_modified_sketch_862434/Blink.ino
/home/***/ARDUINO/arduino-1.8.9/arduino-builder -compile -logger=machine -hardware /home/***/ARDUINO/arduino-1.8.9/hardware -tools /home/***/ARDUINO/arduino-1.8.9/tools-builder -tools /home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -built-in-libraries /home/***/ARDUINO/arduino-1.8.9/libraries -libraries /home/***/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10809 -build-path /tmp/arduino_build_877312 -warnings=all -build-cache /tmp/arduino_cache_4918 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr -verbose /tmp/arduino_modified_sketch_862434/Blink.ino
Using board 'nano' from platform in folder: /home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr
Using core 'arduino' from platform in folder: /home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr
Detecting libraries used...
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_877312/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_877312/sketch/Blink.ino.cpp -o /tmp/arduino_build_877312/preproc/ctags_target_for_gcc_minus_e.cpp
/home/***/ARDUINO/arduino-1.8.9/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_877312/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/***/ARDUINO/arduino-1.8.9/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_877312/sketch/Blink.ino.cpp -o /tmp/arduino_build_877312/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/arduino_cache_4918/core/core_arduino_avr_nano_cpu_atmega328old_a687f7defd46b41b409db8a8fe16211a.a
Linking everything together...
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_877312/Blink.ino.elf /tmp/arduino_build_877312/sketch/Blink.ino.cpp.o /tmp/arduino_build_877312/../arduino_cache_4918/core/core_arduino_avr_nano_cpu_atmega328old_a687f7defd46b41b409db8a8fe16211a.a -L/tmp/arduino_build_877312 -lm
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_877312/Blink.ino.elf /tmp/arduino_build_877312/Blink.ino.eep
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_877312/Blink.ino.elf /tmp/arduino_build_877312/Blink.ino.hex
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_877312/Blink.ino.elf
Sketch uses 930 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/bin/avrdude -C/home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v2 -Pusb -Uflash:w:/tmp/arduino_build_877312/Blink.ino.hex:i
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
An error occurred while uploading the sketch
pert
Which board do you have selected from the Tools > Board menu? I'm not aware of any bootloaders that communicate at 9600 baud. Did you modify boards.txt?
Using Port                    : usb
This indicates you did a Sketch > Upload Using Programmer, but without an ISP programmer connected. Do you have an ISP programmer? Is it connected?
You're really not doing yourself any favors by dumping some random error messages on a random forum thread without bothering to take a few seconds to provide the additional information we need to help you.
4eburashk
Board "Arduino nano".
Yas ~/ARDUINO/arduino-1.8.9/hardware/arduino/avr/boards.txt modified
nano.menu.cpu.atmega328.upload.speed=9600
4eburashk
$ avrdude -v -v -v -v -C /home/***/ARDUINO/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600  -Uflash:w:/tmp/arduino_build_339350/Blink.ino.hex
         Overriding Baud Rate          : 57600
avrdude: Send: 0 [30]   [20]
avrdude: ser_recv(): programmer is not responding
pert
Why did you modify boards.txt?
4eburashk
lowered the transfer rate because it did not work
pert
You need to use an upload baud rate that matches the baud rate of the bootloader. Unless you flashed a modified bootloader to your Nano, there is no chance that it communicates at 9600 baud.
Before you made that modification, did you try doing a standard upload (not Upload Using Programmer) with Tools > Processor > ATmega328P and Tools > Processor > ATmega328P (Old Bootloader)?
4eburashk
Yes. I reflashed microcontrollers many times using Arduino IDE. And well.
After the update, it stopped working. Errors and does not work...
meymuuun
Hey!
 I've seen some simular problems like yours in my MacBook.
There are many bugs in IOS that needs to be fixed. Last time I used Arduino-UnoR3 in my MacBook, I
could not send my codes to the board. I checked everything but.... not working. So I decided to use a
Windows 10 instead. When I use my MacBook for Arduino, I usually use Tinkercad.
107merc
Just tried to upgrade to 1.8.9 from 1.8.6. All my coded programs were written in 1.8.6. None (3) of my Nano's
will upload anymore, all I get is error messages. Unfortunately as the upgrade message suggested I uninstalled
1.8.6 so I can't go back. Checked "tools" and all parameters are correct. Any help appreciated. Error message
is come here and look for suggestions. Thanks
107merc
.9 is gone, .6 is back. Thank you.
pert
You need to select Tools > Processor > ATmega328P (Old Bootloader). This problem is related to the version of Arduino AVR Boards you have installed. The change that requires the Tools > Processor > ATmega328P (Old Bootloader) selection was introduced in Arduino AVR Boards 1.6.23.
The reason you may associate the problem with a particular version of the Arduino IDE is that each version of the Arduino IDE comes with a copy of Arduino AVR Boards pre-installed. The version of Arduino AVR Boards is the current one at the time of the IDE release. The Arduino AVR Boards version bundled with Arduino IDE 1.8.6 was 1.6.22, which the Arduino AVR Boards version bundled with Arduino IDE 1.8.9 is 1.6.23. However, Boards Manager allows you to install any version of Arduino AVR Boards with any version of the Arduino IDE. If you have it enabled in your preferences, you will likely get a notification from the IDE that a new version of Arduino AVR Boards is available. If you follow that notification's advice to update to Arduino AVR Boards 1.6.23, the same requirement to select Tools > Processor > ATmega328P (Old Bootloader) will apply, even though you're using Arduino IDE 1.8.6.
alexblade
hi
anybody know what the reason why USBdetach() still empty in USBCore.cpp in 1.8.9 ?
pert
Which hardware package are you looking at? I just checked Arduino AVR Boards' USBCore.cpp and it doesn't have any mention of a USBdetach() function.
