Topic: Graphics library for NodeMCU (ESP8266), ESP32 and serial+parallel TFT displays (Read 93708 times) previous topic - next topic
bodmer
Hi Stan,
All the really hard work was done by Daniel Eichhorn.  He has some great projects getting the ESP8266 talking to the web and has produced an online book. He designed the splash screen:
He is also knows how to use web API's to for example download images and maps, which I failed to get working in the past:
The weather station code is a great example where the weather icons are fetched from a server.
P.S. You may notice some duff pixels in the images above which were grabbed off the screen. The problem was that reading pixels at 40MHz SPI rate does not work totally reliably.  To be fair though that clock rate is well above the ILI9341 specified limits and thus is "over-clocking" it significantly. So use 27MHz SPI rate if the pixel read functions are going to be used!
ZinggJM
It would be nice if it could run on a larger display like a 3.6 or 3.9 display.
Hi Stan,
3.95" SPI displays are mostly targeted at Raspberry Pi. Some can be easily used with ESP8266, if the connector is not an issue. And the 3.3V interface is ok with ESP8266 (UNO needs level converter).
The one from Waveshare should be usable, I use a Waveshare clone.
And then there is the Waveshare 7" display with RA8875 controller, that I just happen to successfully use with Adafruit_RA8875 over SPI with Wemos D1 and Wemos D1 mini, with a small change in the library to use 4Mhz SPI, at least for initial connection.
Jean-Marc
No personal message please; any question may be useful for other users. Use code tags for code. Make links clickable with URL tags. Provide links to the product in question.
bodmer
The TFT_eSPI library has undergone a few tweaks and bug fixes.
It is also now possible to use the MISO line for the Data/Command (DC) or Chip Select (CS) for projects that are pin constrained and where reading from the display is not needed. This means that for some displays it is possible to get down to using just three I/O pins for SCK, MOSI and DC, with CS tied low to GND and RESET connected to the NodeMCU RST pin.
The background is now correctly sized for rendering the Adafruit "Free Fonts" when using the drawString() member function, here extra width padding has been applied to the plotted numbers with the library setTextPadding() member function, this means old numbers get over-written automatically:
Using the print() method does not use background for technical reasons:
All fonts can be rendered relative to a selected datum, which helps when designing a screen layout:
Online instructions for using the library and features is "in development" and should be available soon!
bodmer
Hi Jean-Marc,
Support will be provided in the TFT_eSPI library in due course for the serial RPi displays based on this type of interface schematic:
This will allow larger resolution displays to be used.  I have a ILI9481 based 480 x 320 touch screen display from China that appears to be well made and is being used for development.
ZinggJM
Hi Bodmer,
These are very welcome news!
Seems we are on a similar track, but I am still a beginner in this field.
My design has evolved a bit:
Code: [Select]
#ifndef _GxIO_H_
#define _GxIO_H_
#include <Arduino.h>
#include <SPI.h>
class GxIO
  public:
    GxIO() {};
    const char* name = "GxIO";
    virtual void reset();
    virtual void init();
    virtual uint8_t transferTransaction(uint8_t d);
    virtual uint16_t transfer16Transaction(uint16_t d);
    virtual uint8_t readDataTransaction()
      return 0;
    virtual uint16_t readData16Transaction()
      return 0;
    virtual void writeCommandTransaction(uint8_t c);
    virtual void writeDataTransaction(uint8_t d);
    virtual void writeData16Transaction(uint16_t d, uint32_t num = 1);
    virtual void writeCommand(uint8_t c);
    virtual void writeData(uint8_t d);
    virtual void writeData(uint8_t* d, uint32_t num);
    virtual void writeData16(uint16_t d, uint32_t num = 1);
    virtual void writeAddrMSBfirst(uint16_t d);
    virtual void startTransaction();
    virtual void endTransaction();
    virtual void setBackLight(bool lit);
#if defined(__AVR) || defined(ESP8266)
class GxIO_SPI : public GxIO
  public:
    GxIO_SPI(SPIClass& spi, int8_t cs, int8_t dc, int8_t rst = -1, int8_t bl = -1);
    const char* name = "GxIO_SPI";
    void reset();
    void init();
    uint8_t readDataTransaction();
    uint16_t readData16Transaction();
  protected:
    SPIClass& _SPI;
    int8_t _cs, _dc, _rst, _bl; // Control lines
class GxIO_SPI3W : public GxIO
  public:
    GxIO_SPI3W(SPIClass& spi, int8_t cs, int8_t dc, int8_t rst = -1, int8_t bl = -1,
               // defaults are for RA8875
               uint8_t cmd_read = 0xC0, uint8_t data_read = 0x40, uint8_t cmd_write = 0x80, uint8_t data_write = 0x00);
    const char* name = "GxIO_SPI3W";
    void reset();
    void init();
  protected:
    SPIClass& _SPI;
    uint8_t _cmd_read, _data_read, _cmd_write, _data_write;
and
Code: [Select]
// GxCTRL.h
#ifndef _GxCTRL_H_
#define _GxCTRL_H_
#include "GxIO.h"
class GxCTRL
  public:
    GxCTRL(GxIO& io) : IO(io) {};
    const char* name = "GxCTRL";
    virtual void setWindow(uint16_t x0, uint16_t y0, uint16_t x1, uint16_t y1);
    virtual void setRotation(uint8_t r);
    virtual void invertDisplay(boolean i) {IO.writeCommandTransaction(i ? 0x21 : 0x20);};
  protected:
    GxIO& IO;
But for RA8875 the separation of display class and controller class not really makes sense.
Jean-Marc
ZinggJM
Btw, your schematics corresponds to the display I know as Waveshare clone/knock off, marked "3.5 inch RPI LCD V3.0 HVGA 480X320". I use it with my "second version" of IO class and display class. It is on the way to be used with my third version.
Jean-Marc
bodmer
Hi Jean-Marc,
My RPi display is off eBay, typical cost is about $15. There seems to be write a few different TFT interface designs out there for the RPi, but the one in post #93 is really convenient for the ESP8266 to drive.
ZinggJM
Hi Bodmer,
It's the same that I have. I bought 2 from 2 different shops:
https://www.aliexpress.com/item/New-26-pin-3-5-inch-Raspberry-Pi-LCD-TFT-Touchscreen-Display-kit-RPI-Touch-Shield/32526486667.html
https://www.aliexpress.com/item/3-5-TFT-LCD-Touch-Screen-Module-320-x-480-SPI-RGB-Display-For-Raspberry-Pi/32661117216.html
and there are more sellers for these on AliExpress.
Avoid the 3.5" tfts marked KeDei, it uses 3 wire SPI, and no schematics can be found.
My attempts to use it with Arduino failed; I have some idea from observing on Raspi with logic analyzer, and may give it another try with my new IO class. Controller is unknown, polarity is reversed, etc.
Jean-Marc
bodmer
The library has been updated to support Raspberry Pi 480 x 320 displays based on the ILI9486 TFT driver and with a 16 bit interface.
This is an example of the compatible display.
The display must be of the same interface design comprising 74HC04, 74HC4040 and 2 off 74HC4094 devices. These are commonly 3.5" TFTs compatible with the Waveshare design.
See also Jean-Marc's web links and post #93.
Since 16 bits has to be sent for every transaction there is a small overhead and thus the display draw performance is constrained.
The performance is reasonable, the TFT interface built onto the back of the TFT will only support a 20MHz rate unless modifications are made. This is a limit of the display interface design.
The UTFT Demo runs in 3s
Typical 480 x 320 results at 20MHz SPI for the GFX graphicstest sketch are:
Code: [Select]
TFT_eSPI library test!
Benchmark                Time (microseconds)
Screen fill              625771
Text                     37269
Lines                    502658
Horiz/Vert Lines         58450
Rectangles (outline)     32978
Rectangles (filled)      1511987
Circles (filled)         359877
Circles (outline)        290419
Triangles (outline)      104101
Triangles (filled)       599591
Rounded rects (outline)  132635
Rounded rects (filled)   1726473
Done!
For a 320 x 240 display the equivalent results would be:
Code: [Select]
Screen fill              312986
Text                     24360
Lines                    150932
Horiz/Vert Lines         28403
Rectangles (outline)     18591
Rectangles (filled)      641954
Circles (filled)         137072
Circles (outline)        88468
Triangles (outline)      36436
Triangles (filled)       251335
Rounded rects (outline)  47381
Rounded rects (filled)   734838
Done!
bodmer
#99
Mar 27, 2017, 03:28 am Last Edit: Apr 07, 2017, 03:41 pm by bodmer Reason: Add comment about diode
The library has been updated to add support for a Raspberry Pi ILI9486 480x320 display with a modification made to the circuit that adds a directly controlled write strobe:
This allows fast writing of blocks of repeated colour pixels.  The complete 480x320 screen can then be cleared in 23ms and the Run Length Encoded fonts render very fast too (1.2ms for a 72 pixel high digit).  Other graphics functions that write sequences of the same colour to the screen are also speeded up significantly.
The 480x320 adapted "UTFT" graphics test sketch now runs in 1.6s and the Adafruit GFX style graphicstest runs 3x faster at 1.95s:
Code: [Select]
Screen fill              115291
Text                     28714
Lines                    393270
Horiz/Vert Lines         11581
Rectangles (outline)     8164
Rectangles (filled)      279258
Circles (filled)         186516
Circles (outline)        240076
Triangles (outline)      78149
Triangles (filled)       167982
Rounded rects (outline)  94215
Rounded rects (filled)   348198
Done!
Total = 1.9496
Update:  The diode must be a low capacitance type, so power diodes are not suitable for the mod circuit.  A 1N4148 diode works fine and has been tested at 27MHz SPI clock rate without problems. However I have replaced it with a lower Voltage drop BAT85 schottky diode, this achieves a lower logic "0" voltage when the TFT_WR line is pulled low by the NodeMCU.
Stan_S
Hi Bodmer,
looks like you have another great library, I just ordered a 3.5" display to try out. The plane spotter sketch as well as the META weather one.
Thanks for all  your efforts.
Regards,
Stan
bodmer
Hi Stan,
The larger 480 x 320 screen is great, but it is the most expensive TFT I have in a project at $15. I have not tried to use the touch screen yet and may not bother as I find these resistance based touch screens scratch very easily.
I have combined the weather and clock sketches into one so each occupies half the screen and that works well. When you have your screen up and running then I can make a copy available if you are interested. The only issue is that the clock seconds hand freezes every 10 minutes for about 10s when the weather update information is fetched  from the web, so I may remove that or blank out the second hand it during updates.
I hope to get the Plane Spotter sketch running full screen on 480x320 too but I am going to be very busy with paid work for a few weeks so that will have to wait.
bodmer
A new RPi 4" "WaveShare" 480x320 screen arrived today. This is destined for a RPi project  but I have connected it the the ESP8266 NodeMCU board and the TFT_eSPI library runs fine with it.
In case anyone is interested in using this larger screen then here is a link to the eBay page. Note the postal charge! There are other advertisers that sell these displays at a slightly lower cost.
As is often the case with displays from China the images in the advert do not correspond exactly with the delivered screen but it works fine, it does have the WaveShare logo and is marked "4 inch RPi LCD (A)".
Due to the very restrictive PCB track and PCB pad access it would be much trickier to add the speed enhancing mod detailed in post #99 , but the drawing performance is still very good even with no modifications.
bodmer
In response to a PM, here are the connections for the RPi display with the TFT_eSPI library:
Stan_S
Hi Bodmer,
I just got my display today, thanks for posting the pin out as it is not marked.
Regards,
Stan
