Topic: Bench power supply suggestions (Read 6792 times) previous topic - next topic
TomGeorge
Most power supplies have either the banana plug sockets or screw posts, one the plug can pull out, the other a pain to use if in a hurry and hole in post is out of site due to fingers in the way.
Solution, spring loaded terminals;
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
Boardburner2
#46
Jan 01, 2017, 08:07 pm Last Edit: Jan 01, 2017, 08:07 pm by Boardburner2
+1 for spring loaded terminals.
I found that the lever type used for speaker terminals were more convinient than the plunger type to use.
larryd
#47
Jan 02, 2017, 07:06 am Last Edit: Jan 02, 2017, 07:06 am by LarryD
FYI
I use these containers for storing leads etc.
http://www.ebay.ca/itm/321985115125?ul_noapp=true
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Watcher
#48
Jan 02, 2017, 10:46 am Last Edit: Jan 02, 2017, 10:49 am by Watcher
I use something like this for storing leads and small things
Boardburner2
#49
Jan 02, 2017, 05:13 pm Last Edit: Jan 02, 2017, 05:16 pm by Boardburner2
FYI
Santa pushed the boat out this year  :)
[/url]
Boardburner2
Maybe we will get a new dress, high heels and a new purse for our birthdays. ;)
It was a Lois Viton handbag.  >:(
So hoping it was a knockoff.
MAS3
Well if it was a Lois Viton, then it was indeed a knockoff of a Louis Vuitton.
:P
Sorry, couldn't let that one go.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
