Topic: About pins ... (Read 18050 times) previous topic - next topic
Jiggy-Ninja
Do not throw your Arduino out just yet.
Remove all wires from your Mega and upload this sketch. This connects the ADC to two internal signals (GND and the 1.1V bandgap reference) and reads them. It should print out 0 and 161 (give or take a few) to the Serial monitor. If you still get 512-ish with this sketch, your chip is broken. If you get the expected values, your ADC is fine and the external circuit is most likely faulty.
Code: [Select]
#include "wiring_private.h"
  ADMUX = 0x40 + B011111;
  sbi(ADCSRA, ADSC);
  while(bit_is_set(ADCSRA, ADSC));
  Serial.println(ADC);
  ADMUX = 0x40 + B011110;
  sbi(ADCSRA, ADSC);
EasyGoing1
Nope, it gives me 0 and 512
Well, since I wasn't actually using a circuit to do my tests (I had a scope plugged directly into the port), I had little hope that I would get a good reading with your sketch.
I suppose there is no way to simply repair this board?  Perhaps replacing the main chip would be cheaper than purchasing a new board?
Thank you for your help.
Mike Sims
Mike Sims
Jiggy-Ninja
#17
Feb 01, 2017, 07:25 pm Last Edit: Feb 01, 2017, 07:26 pm by Jiggy-Ninja
Well that's unfortunate.
Quote
Mike Sims
Do you have a second Arduino that you can use to flash the new chip with the bootloader? If you do, and you think you can handle replacing a 100 pin TQFP, then by all means go for it. :)
