Topic: Share tips you have come across (Read 178204 times) previous topic - next topic
MAS3
Hi.
How about this product range (click !) ?
It will set you back 15 euros or something in that range.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
larryd
#796
Oct 30, 2020, 04:58 pm Last Edit: Oct 30, 2020, 06:05 pm by larryd
Micro glue tips can really help when you want to apply small amounts of CA and other glues in your project enclosures.
These are resistant to the DCM solvent also.
Good for adding small amounts of oil to mechanical parts.
Insert a 26/24 gauge wire in the tube if you need further flow restriction.
These are available on Amazon and eBay at reasonable prices, about $20 for 100 or more.
Have not tried but these might be okay for solder paste application too.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
larryd
#797
Nov 04, 2020, 04:51 pm Last Edit: Nov 07, 2020, 06:26 pm by larryd
For the 12th time I will try to get this new post made.
A good flux applicator and bottle, images to follow.
No technical PMs.
ballscrewbob
Lay off the alcohol  :D
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
larryd
#799
Nov 08, 2020, 12:07 am Last Edit: Nov 09, 2020, 05:48 pm by larryd
" Lay off the alcohol  :D"
Helps get you thru the frustration from 'Coudflare'.
Finally the Arduino web site is properly working again !
Here are the images for post #797
No technical PMs.
Henry_Best
larryd
#801
Nov 18, 2020, 07:25 pm Last Edit: Nov 18, 2020, 07:34 pm by larryd
Further to making a sheath for your tools.
Add Teflon tape (used on pipe threads) over the tool end, use glue lined 4:1 Heat Shrink as the sheath.
The Teflon prevents the glue from sticking to the tool.
Pull off the sheath, discard the Teflon tape.
No technical PMs.
larryd
#802
Nov 19, 2020, 08:29 pm Last Edit: Nov 20, 2020, 06:33 am by larryd
Seal cables and other items with glue lined heat shrink.
No technical PMs.
Bjerknez
I just have to say, this must be the most informative and usefull thread on the internet regards to electronic works etc. Special thanks to larryd, and all good tips!!! Awsome!
Btw. It is okay that i repost some of the posts in an norwegian forum for electronics? What is the rules regards to that?
ballscrewbob
#804
Nov 20, 2020, 01:39 pm Last Edit: Nov 20, 2020, 01:40 pm by ballscrewbob
@Bjerknez
As a Moderator I have no objection.
Where TEXT is involved you may want to TRANSLATE.
Bob
Bjerknez
@Bjerknez
Bob
Ok, thanks :)
