Topic: Share tips you have come across (Read 145214 times) previous topic - next topic
larryd
Jan 04, 2017, 08:20 am Last Edit: Jan 04, 2017, 08:21 am by LarryD
How about sharing some tips you use?
Here is one I use often when I need my third hand to give a constant pull.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
terryking228
Hi Larry,
I started THIS on http://ArduinoInfo.Info
May I add yours??
Anyone else??
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
larryd
#2
Jan 04, 2017, 06:49 pm Last Edit: Jan 05, 2017, 02:14 am by LarryD
Terry, feel free use ideas.
There must be lots of us old guys around with time saving ideas.
Two more ideas.
Make a breadboard friendly Neopixel for software development.
Make breadboard friendly switch assemblies from two pin SMD switches.
The center header pins are pulled out and discarded.
Avoid plugging header pins next to the center of the breadboard, use these holes for DIP sized pins only.
No technical PMs.
terryking228
#3
Jan 04, 2017, 11:44 pm Last Edit: Jan 04, 2017, 11:44 pm by terryking228
Jiggy-Ninja
Hackaday: https://hackaday.io/MarkRD
Advanced C++ Techniques: https://forum.arduino.cc/index.php?topic=493075.0
larryd
#5
Jan 05, 2017, 01:14 am Last Edit: Jan 05, 2017, 01:15 am by LarryD
@Jiggy-Ninja
The Hakko soldering iron tips are great.
It is nice to have an assortment of shapes and sizes for different soldering jobs.
As I mentioned in a previous thread, this is my new goto soldering iron tip of choice:
Edit
I shouldn't have used goto ???
No technical PMs.
larryd
#6
Jan 05, 2017, 02:17 am Last Edit: Jan 05, 2017, 02:19 am by LarryD
Put metal, stainless steel and/or copper, scouring pads into an old tin can to make a convenient soldering iron tip cleaner.
You can find these scouring pads at grocery stores.
No technical PMs.
larryd
#7
Jan 06, 2017, 06:35 am Last Edit: Jan 06, 2017, 06:36 am by LarryD
Use an old nail polish bottle to hold liquid flux for soldering.
Clean out the dried polish from the bottle using Acetone.
No technical PMs.
TKall
Really useful tips LarryD.  Thank you.
pert
Any preference between stainless and copper. Is there any benefit to using both metals or was that just because you bought  a combo pack of pads? What about brass? I think that's what's in the one I have. Have you compared these to using a wet sponge? I've never used a sponge but always wondered if there was a drawback to this style of tip cleaner.
Any reason why you prefer this to the squeeze bottles with the syringe tips? I recently got one of those and much prefer it because if I accidentally knock the bottle over it's only a drop spilled at the most.
larryd
#10
Jan 07, 2017, 03:01 am Last Edit: Jan 07, 2017, 03:30 am by LarryD
Personally I like to use a damp sponge at times.
I find it shocks the iron prior to tinning the tip and I think I get better results.
Metal hardness would be stainless brass and then copper.
If there is a concern whether the irons tip will wear then copper would be a good choice.
Stainless is more abrasive.
Stainless does not let melted solder adhere to it so it does not get loaded with solder.
Brass is more expensive and harder to find here.
I have purchased stainless and copper in separate packaging only.
I prefer using copper pads as long as the iron does not cool down sitting in it.
If it does, the iron will then stick to the copper where there is contact.
Having both stainless an copper lets you decide which to use at a given time.
I use a plastic squeeze bottle with a syringe needle where I need to flood an area.
In the image, you will see a plastic insert, its  purpose is to prevent fluid leaking out when the bottle is tipped over.
I like using the brush that comes with the bottle as it can apply flux accurately on the work.
A brush is also better when working on vertical components.
Edit
Don't let the owners bottle know you stole it ;)
No technical PMs.
MarkT
It makes sense to only use a cleaning pad that is softer than the iron-plated surface of a soldering
bit, otherwise you will abrade that surface and shorten the life of the bit - so copper OK, stainless not
OK.  Wet sponge is all I normally use personally.
pert
I've never had the solder stick to the brass and it's softer than stainless steel so I guess that's a pretty good material for the  purpose, though less readily available for making a DIY tip cleaner. I bought a pre-made one on eBay from China for <$2USD w/ free shipping. I pull the brass out of the can every so often and all the little bits of solder fall out with a couple taps.
I didn't realize the purpose of the plastic insert. That would have come in handy a couple times with my old flux bottle. I ended up gluing the thing to a piece of steel flat bar to give it a stable base.
Jiggy-Ninja
#13
Jan 08, 2017, 09:59 pm Last Edit: Jan 08, 2017, 10:07 pm by Jiggy-Ninja
If you've got some thing you need to use frequently that requires a complicated wiring arrangement, make a jig on some protoboard so you will know it works every time and not have to fiddle around with troubleshooting it every time you wire it up.
I made jigs for reprogramming chips outside of an Arduino board.
Above are two examples of programming jigs I made. One is a ZIF socket soldered onto a protoshield that lets me use the ArduinoISP sketch on an Uno to program a chip (in this case, an ATtiny4313).
The other is some male headers soldered onto a 6-wide protoboard. The 2x3 header on top lets me plug in the standard programmer ribbon cable, and the headers on bottom are spaced just wide enough to be able to plug this over a DIP package in a breadboard. You just need to grab the right jig and plug it over the chip to reprogram it in circuit. The one pictured is made for an ATtiny85.
I have one of each jig made for ATtiny85, ATtiny84, ATtiny4313, and ATmega328P.
Which reminds me, I need to whip some up for the ATtiny10 and various PICs I bought.
larryd
#14
Jan 08, 2017, 11:21 pm Last Edit: Jan 20, 2017, 07:24 am by LarryD
@Jiggy-Ninja
That is a great idea.
I purchased 10 of these boards to do something similar.
eg: I plan on making these: IR remote control, Temperature, RTC, ultra sonic distance sensor and RFID.
Once made up, I will be able to just plug and play ;)
http://www.banggood.com/10Pcs-Prototyping-Shield-PCB-Board-For-Arduino-p-1013120.html?rmmds=myorder
WARNING the PCB linked to here has a circuit error.
You Must corrected this error before you plug it onto an Arduino.
No technical PMs.
