Topic: SIM800L GPRS GSM ( ROHS ) restarts every 10 seconds  (Read 9858 times) previous topic - next topic
caslor
Hi
i am experiencing the above problem with this module
i am using Arduino mega 2560 with this one and  i am including  the SoftwareSerial.h  to declare pins  10 and 11  as  RX and TX in my code
my PIN connections to this module are
SIM800 5v/4v ↔ Arduino 5v  (or external power through MB102 Breadboard Power Supply Module 3.3V/5V For Arduino Breadboard.. This one below  )
SIM800 GND (first one) ↔ Arduino GND
SIM800 SIM_TXD ↔ Arduino D10 TX
SIM800 SIM_RXD ↔ Arduino D11 RX
SIM800 GND (second one) ↔ Arduino GND For common reference for tx,rx
With the Sim card in place  and through the Serial monitor  i can send  AT comands and receive back messages
Sending  AT    and get   :
OK
+CPIN: READY
Call Ready
SMS Ready
Sending  AT+CFUN?    and get   :
+CFUN: 1
Sending  AT+CREG?    and get   :
+CREG: 0,2
Sending  AT+COPS?    and get   :
+COPS: 0
Sending  AT+CMGF=1    and get   :
OK
Sending  AT+CSMP?    and get   :
+CSMP: 17,167,0,0
But all of these commands i can send them only between the 10 seconds that takes before  restarts again
The module has 2 leds... the one red is always ON in these 10 seconds  and the second one  also red in colour is blinking
When i dont have the SIM card inside the slot  the module doesn't Restart , is always on   with the 2 leds working as i describe above
Any one with the same problem and perhaps a solution to this? what i am doing wrong ?
caslor
OK i find out something strange....
This happens only when i have connected the Antenna to the module
When the antenna is out  the module works fine without restarting  (i havent test it to send AT comands but i am guessing it will not be able to find the gsm network
SO any idea about this ?
Thanks in Advance
scrumfled
Youre not giving it enough power. Those board supplies are typically 5-700ma
Id imagine without the ant, the device fails to see a network. When you add the ant it sees the network and attempts registration...which ups the power requirement as the tx stage fires up.
zstergios
pauloh747
#4
Sep 15, 2017, 12:45 am Last Edit: Sep 15, 2017, 01:03 am by pauloh747
I have the same problem with the SIM808. Did you get it to work?
zstergios
Try to connect with a charged LIPO 3.7 or charger that provides 2A and voltage under 4.4
You have to connect the GND of arduino with GND of LIPO (common GROUND)
IF does not work, buy sim800L (red pcb), I never had problem as the above module
neki_deki
hi!
i am using the same module, and have the same problem like mr caslor. from my experience in this sim800l v2.2 module, it is not problem with power supply, because i am using laboratory power supply that can provide more than 2A. I did test 3 sim cards, and all 3 of them behave differently. i tested 2 sim cards of same network operator but 1 was newer and micro type, and another was nano with adapter. when i was using micro sim card from that operator, one led that continuously lighted and another was lighted 8 times and then module was reset. sim card from another operator: one led was lighted continuously and another was lighted 10 times and then reset.
the older sim card from 1st operator - micro sim card was around 4 years old. with that card i have no reset but also no connection to mobile network.
at+cops?
+COPS: 0
OK
Bole
Quote
It is not guarantee you are supplying GSM module the right way. sim800l needs power supply voltage 3.4-4.4V recommended 4V. Burst may produce problems because i can pull up to 2A current and if you have long wires it may produce voltage drop across it and GSM module will reset. It is good practice to solder electrolytic capacitor as close to the module as possible. I use 1000uF 6.3V cap and it helps. It is better to use a couple of lower capacity low ESR type capacitors.
On this link you'll find the pdf document http://wiki.seeedstudio.com/images/4/46/SIM800L_Hardware_Design_V1.00.pdf
Look at page 21 and couple next pages for sim800l power supply recommendations.
Best regards...
neki_deki
mr bole, thank you for your answer very much!
i find a problem. and i believe that your solution with capacitor of 1000mf close to connector on module would solve the problem as well. the problem was wire that i was using to connect sim800l. i was using this type of wires
http://www.5thpostulate.com/image-smp/5pe-male-female-jumper-wires-dupont-arduino-cables-8-cm-pack-of-10-dupont-arduino-jumpers_78503_1000x1000.jpg
i believe that this type of wires is very tiny to provide enough current in the moment that module is starting to send/receive gsm signal.
only thing i did, i put this type of connector
https://www.allelectronics.com/mas_assets/cache/image/4/4/3/480x480-1091.Jpg
and connect female one directly to sim800l module.
i am using:
https://www.tokopedia.com/viekashop/sim800l-v20-sim-800l-gprs-gsm-module-sim-board
my
Work voltage: 3.7~5V
few minutes ago, i make a first call to the module from my cell phone... can you imagine how i was happy when i saw a massage RING on terminal :D :)
mojtaba_sh
#9
Jul 22, 2018, 05:26 am Last Edit: Jul 22, 2018, 05:34 am by mojtaba_sh
Hey guys,
I had the same problem on sim800c
and increasing voltage to 4.1 volts fixed the problem
on 4.00 volts it power's down after about 10 seconds blinking of net led
gopalreddy
use 1000uF 6.3V cap and it helps. It is better to use .
in gsm wants to 5v,1.5-2A .we place a cap b/w vcc,and gnd
Topo_AS
power the sim module directly from external 5V min. 2Amp power supply ( do power from the board) and must work.
KASSIMSAMJI
sim800l has some naked SMDs on it, you don't want to put your bare hands on them, i impaired one long ago when i was a noobie ,
hold the board on it's edges,
Expert To Be: Machine Learning And Computer/Machine Vision (ML/CV/MV)
cz-themax
I had the same problem but I solved it by replacing the tantalum capacitor on the SIM800L EVB. On my board was 107, which is 100uF, I changed it to 108, which is 1000uF. I made the exchange on all five modules I've bought on aliexpress and have been working since then.
jabalv
This is interesting solution. Where did you found 108 tantalum capacitor? I found that they cost about same as whole board from aliexpress :)
