Topic: how to create / buy a servo horn for 28BYJ-48 engine ? (Read 1 time) previous topic - next topic
fabertel
anyone can suggest how to create / buy some servo horn for 28BYJ-48 engine to connect items to it ?
I've tried to sandwitch the engine pin with 2 metal bars with bolts but its still not stable .
thanks,
Fabio
Robin2
What is the diameter of the shaft?
I have successfully used the brass inserts from large chocolate-block connectors for connections on some motor shafts.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
terryking228
#2
Jan 09, 2017, 03:44 pm Last Edit: Jan 09, 2017, 03:45 pm by terryking228
Do you mean THESE MOTORS?
I would really like to find attachments for these!
  • Servo horn
  • And especially Wheels to make small robots...
Anyone seen these?? Thanks!
And what are these??
Quote
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
jremington
The shaft on my version of the 28BJY motor is 5 mm in diameter, which is standard.
You need two setscrews, one on each side of a 5 mm bore gear to engage the flats.
fabertel
thanks everyone for your feedbacks !
Robin2 : the chocolate-block connectors .. really cool . I'll try..   https://goo.gl/images/OSvuJI
terryking228 : yes , this motor .
jremington : im not sure i got your idea .. can u detail little bit ?
thanks,
Fabio
jremington
#5
Jan 09, 2017, 05:44 pm Last Edit: Jan 09, 2017, 05:51 pm by jremington
Below is a picture of a pinion gear with a single set screw.
Imagine a second set screw on the opposite side of the shaft.
Instead of a servo horn or arm, consider using a hub, like this one (you would need a 5 mm bore).
fabertel
MarkT
And of course there is thingiverse...
https://www.thingiverse.com/tag:28BYJ-48
