Topic: 9V battery question. (Read 2037 times) previous topic - next topic
BayBayMan
I am using a 6V power source for a gas sensor I'm using. Then I'm using the on board 5V to power an LCD I am using. So, I am using two power sources.
My question is if I wanted to use a 9V battery, would that be able to power both components without needing to use a USB cable? I want to make my gas sensor more mobile and portable. I don't know much about power sources, and whether or not something is getting enough power.
Thanks!
Robin2
#1
Jan 10, 2017, 08:42 pm Last Edit: Jan 10, 2017, 08:43 pm by Robin2
If you mean a PP3 style of 9v battery the answer is NO. they cannot provide enough current.
But a pack of 6 x AA cells should be sufficient.
HOWEVER, if the gas sensor needs precisely 6v, or a max of 6v you will not be able to power it from a 9v battery without something to regulate the voltage.
Best thing is to post a link to the datasheet for your gas sensor.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
BayBayMan
http://eph.ccs.miami.edu/precise/GasSensorSpecs/Ozone.pdf
I do have a PP3 9V battery, but am looking into those 6xAA cell holder. I kinda figured it was common sense that 9V wouldn't support 6V + 5V = 11V. I just thought there might be some kind of extra black magic in there that would allow 9V to power 11V worth of components.
What would you suggest I use for 11V+ worth of power?
CrossRoads
A boost regulator. Take a look at regulators at www.pololu.com
Robin2
#4
Jan 10, 2017, 10:16 pm Last Edit: Jan 10, 2017, 10:18 pm by Robin2
You have no need for 11v worth of power. Adding the voltages as you have done is all wrong. If you had a 2-seater car and a 4-seater car you would not have a 6-seater car.
You have an sensor that requires a precise 6v supply for its heater and if you have an Uno it requires a supply voltage between 7v and 12v. In the circuit diagram in the datasheet they use a 7806 voltage regulator to produce the 6v supply and you could also use one of them with your 9v battery.
However the datasheet says it requires a circuit voltage of 5v and I cannot figure how that is used or whether it could be provided by the Arduino's 5v pin. Is that sensor suitable for use with a microprocessor?
...R
BayBayMan
Ah, thank you for that analogy. I was pretty ignorant in how voltage works. It seems I have to look up some tutorials on how exactly that power issue could work out. I am looking into a boost regulator, as CrossRoads suggested.
I believe the gas sensor is suitable for a microprocessor. This is the sensor: https://www.amazon.com/Sensitivity-Detection-Testing-Sensor-Module/dp/B01FJC12XW/ref=sr_1_2?ie=UTF8&qid=1484084779&sr=8-2&keywords=mq131
MarkT
Thanks!
The gas sensor alone is rated at 900mW, ie about 150mA, which is beyond the ability of a small 9V battery to
power properly (if at all).
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
BayBayMan
That's interesting. Most tutorials show the MQ series gas sensors connected straight to the Arduino board, using the on board 5V. What would you suggest I use to power this sensor? I want to be able to make this sensor portable and mobile.
Thanks for the info!
MarkT
It contains a 1W heater, it won't run for long battery powered without a decent sized battery.  It will also have
a minimum-time-till-stable after the power is applied for the sensor to heat up too.
BayBayMan
Alrighty. It seems I need to research some options for some portable power, and how to connect it to the arduino board. Thanks, Mark!
