Topic: sd card Could not find FAT16/FAT32 partition [solved] (Read 8755 times) previous topic - next topic
suziosaurus
Jan 12, 2017, 04:41 am Last Edit: Jan 12, 2017, 05:26 am by suziosaurus
Hi, :o
While I was checking with sd card connection,
the error message was shown like below:
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Could not find FAT16/FAT32 partition.
Make sure you've formatted the card
How can i fix the problem?
I've just bought micro sd card (samsung microSDXC) so i don't think it's a problem of old version..
Thanks for any help!
pert
Which version of the SD library are you using(can be checked at Sketch > Include Library > Manage Libraries...)? There is an issue with 1.1.0 but 1.1.1 should fix it.
mrsanugraha
Hi @suziosaurus,
Check below hyperlink. Similar problem was identified before.
http://forum.arduino.cc/index.php?topic=296324.0
I just followed  suggestion from @oric_dan to use SdFat library from github, and it works.
