Topic: Hex Code for Keyboardkey "rmenu"? (Read 656 times) previous topic - next topic
CypherXG
Hello.
I read this https://forum.arduino.cc/index.php?topic=139358.0 in the Forum.
"AMIGA 500/1000/2000 Keyboard Interface"
I connect the Amiga 500 Keyboard with my Arduino Leonardo.
All seems to be fine, but on the Keyboard the "right Amiga key" dont work.
This key is the "rmenu" Key for a normal Windows Keyboard.
Can someone tell me the right Hex Code for this key on the Keyboard?
Here ist the Arduino Code:
Code: [Select]
#include <Keyboard.h>
#define BITMASK_A500CLK 0b00010000    // IO 8
#define BITMASK_A500SP  0b00100000    // IO 9
#define BITMASK_A500RES 0b01000000    // IO 10
#define SYNCH_HI        0
#define SYNCH_LO        1
#define HANDSHAKE       2
#define READ            3
#define WAIT_LO         4
#define WAIT_RES        5
#define HID_SendReport(id,data,len) HID().SendReport(id,data,len) // IDE 1.6.9
KeyReport _keyReport;
uint32_t counter = 0;
uint8_t Joy, MemoJoy1, MemoJoy2, state, bitn, key, fn,keydown, ktab[0x68]={
  // Tilde, 1-9, 0, sz, Accent, backslash, Num 0 (00 - 0F)
  0x35, 0x1E, 0x1F, 0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x2D, 0x2E, 0x31,    0, 0x62,
  // Q bis +, -, Num 1, Num 2, Num3 (10 - 1F)
  0x14, 0x1A, 0x08, 0x15, 0x17, 0x1C, 0x18, 0x0C, 0x12, 0x13, 0x2F, 0x30, 0   , 0x59, 0x5A, 0x5B,
  // A-#, -, Num 4, Num 5, Num 6 (20 - 2F)
  0x04, 0x16, 0x07, 0x09, 0x0A, 0x0B, 0x0D, 0x0E, 0x0F, 0x33, 0x34, 0x32, 0,    0x5C, 0x5D, 0x5E,
  // <>,Y- -, -, Num . , Num 7, Num 8, Num 9 (30 - 3F)
  0x64, 0x1D, 0x1B, 0x06, 0x19, 0x05, 0x11, 0x10, 0x36, 0x37, 0x38,    0, 0x63, 0x5F, 0x60, 0x61,
  // Space, BS, Tab, Enter, Return, ESC, Del, -, -, -, Num -, -, up, down, right, left (40 - 4F)
  0x2C, 0x2A, 0x2B, 0x58, 0x28, 0x29, 0x4C,    0,    0,    0, 0x56,    0, 0x52, 0x51, 0x4F, 0x50,
  // F1-F10, -, -, Num /, Num *, Num +, - (50 - 5F)
  0x3A, 0x3B, 0x3C, 0x3D, 0x3E, 0x3F, 0x40, 0x41, 0x42, 0x43,    0,    0, 0x54, 0x55, 0x57,    0,
  // modifiers: Shift left, Shift right, -, Win left, Ctrl left, Ctrl right, Alt left, Alt right
0x02, //SHIFT-LINKS
0x20, //SHIFT-RECHTS
0x00,
0x01, //LINKS-CTRL
0x04, //RECHTS-ALT
0x40, //LINKS-AMIGA
0x08, //LINKS-ALT
0x10, //Sollte die Menü Taste sein. Geht aber nicht
    //0x02, 0x20, 0x00, 0x08, 0x01, 0x10, 0x04, 0x40
  // Keyboard (Port B)
  DDRD = ~(BITMASK_A500CLK | BITMASK_A500SP | BITMASK_A500RES);  // direction INPUT
  // Keyboard
    if (((PINB & BITMASK_A500RES)==0) && state!=WAIT_RES) {   // Reset
    interrupts();
    keystroke(0x4C,05);        // CTRL+ALT+DEL
    fn=0;
    state=WAIT_RES;
  else if (state==WAIT_RES) {   // Waiting for reset end
    if ((PINB & BITMASK_A500RES)!=0) state=SYNCH_HI;
  else if (state==SYNCH_HI) {   // Sync-Pulse HI
    if ((PINB & BITMASK_A500CLK)==0) state=SYNCH_LO;
  else if (state==SYNCH_LO) {   // Sync-Pulse LOW
    if ((PINB & BITMASK_A500CLK)!=0) state=HANDSHAKE;
  else if (state==HANDSHAKE) {  // Handshake
    if (counter==0) {
      DDRB |= BITMASK_A500SP;   // set IO direction to OUTPUT
      PORTB &= ~BITMASK_A500SP; // set OUTPUT to LOW
      counter=millis();
    else if (millis()-counter>10) {
      counter=0;
      DDRB &= ~BITMASK_A500SP;   // set IO direction to INPUT
      state=WAIT_LO;
      key=0;
      bitn=7;
  else if (state==READ) {        // read key message (8 bits)
    if ((PINB & BITMASK_A500CLK)!=0) {
      if (bitn--){
        key+=((PINB & BITMASK_A500SP)==0)<<(bitn); // key code (add bits 0...6)
        state=WAIT_LO;
      else {  // read last bit (key down)
        keydown=((PINB & BITMASK_A500SP)!=0); // true if key down
        interrupts();
        state=HANDSHAKE;
        if (key==0x5F)  fn=keydown;  // "Help" key: special function on/off
        else if (key==0x62) keystroke(0x39,0x00);  // CapsLock
        else {
          if (keydown){
            // keydown message received
            if (fn) {
              // special function with "Help" key
              if (key==0x50) keystroke(0x44,0);  // F11
              else if (key==0x51) keystroke(0x45,0);  // F12
              else if (key==0x5A) keystroke(0x53,0);  // NumLock
              else if (key==0x5B) keystroke(0x47,0);  // ScrollLock
              else if (key==0x02) keystroke(0x14,0x40);  // @
              else if (key==0x04) keystroke(0x35,0x02);  // °
            else {
              if ((key==0x2B) && (_keyReport.modifiers & 0x22)) keystroke(0x35,0x00);  // ^ (with shift)
              else if (key==0x00) if (_keyReport.modifiers & 0x22) keystroke(0x30,0x40); else keystroke(0x35,0x20); // ~,`
              else if (key==0x0D) if (_keyReport.modifiers & 0x22) keystroke(0x64,0x40); else keystroke(0x2D,0x40); // |,\
              else if (key==0x5A) if (_keyReport.modifiers & 0x22) keystroke(0x24,0x40); else keystroke(0x25,0x40); // {,[
              else if (key==0x5B) if (_keyReport.modifiers & 0x22) keystroke(0x27,0x40); else keystroke(0x26,0x40); // },]
              else if (key < 0x68) keypress(key);  // Code table
          else {
            // keyrelease message received
            if (key < 0x68) keyrelease(key);  // Code table
  else if (state==WAIT_LO) {   // waiting for the next bit
    if ((PINB & BITMASK_A500CLK)==0) {
      noInterrupts();
      state=READ;
void keypress(uint8_t k) {
  if (k > 0x5f) _keyReport.modifiers |= ktab[key];  // modifier
  else {
    for (uint8_t i=0; i<6; i++) {
      if (_keyReport.keys[i] == 0) {
         _keyReport.keys[i] = ktab[key];
  HID_SendReport(2,&_keyReport,8);
void keyrelease(uint8_t k) {
  if (k > 0x5f) _keyReport.modifiers &= ~ktab[key];  // modifier
  else {
      if (_keyReport.keys[i] == ktab[key]) _keyReport.keys[i] = 0;
void keystroke(uint8_t k, uint8_t m) {
  unsigned short memomodifiers = _keyReport.modifiers; // save last modifier state
         _keyReport.keys[i] = k;
         _keyReport.modifiers = m;
         _keyReport.modifiers = memomodifiers; // recover modifier state
The problem is in this row:
0x10 don't work. Also i thin the Hex key is 0x67, but this also does't work.
Can it be that I may have to change the keyboard.h?
Please note that the following keys
0x02, // SHIFT-LINKS
0x20, // SHIFT-RECHTS
0x00,
0x01, // LINKS-CTRL
0x04, // RECHTS-ALT
0x40, // LINKS-AMIGA
0x08, // LINKS-ALT
works with an Amiga emulator perfectly
Can anybody fix this?
Greets Markus
