Topic: ATtiny and tone() (Read 14792 times) previous topic - next topic
silly_cone
well glad I could be of assistance.  :-)
I'm glad there's a rational explanation; I was starting to feel l like I was going a little crazy.  :P
silly_cone
Alright, back to this again...
Anyone have any insight into why analogWrite would stop working on PB4 when tone() function is used in the sketch?
analogWrite still works on PB0 and PB1, but if I use the tone() command anywhere, even if its ended by a call to noTone(), analogWrite on PB4 is still dead.
Coding Badly
Which tone?  You have used at least three variations.
DrAzzy
Which core is it? Is it my core?
If it's my core, please make an issue here: https://github.com/SpenceKonde/ATTinyCore/issues - my guess from the problem description is that it's an x5 series, but please confirm that. I also *love* code that reproduces problems, even really simple ones.
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
silly_cone
That's right, its an ATTiny85.
This code results in proper output signal on PB4:
  pinMode(4, OUTPUT);
  //tone(2, 5000);
  delay(1);
  //noTone(2);
  delay(1);
  for (int i=150; i>85; i--){
    analogWrite(4, i);
  delay(2000);
  digitalWrite(4, LOW);
  delay(2000);
This code results in nothing from PB4. but interestingly, it produces a ~25 ohm connection to ground that isn't present otherwise.
  pinMode(4, OUTPUT);
  tone(2, 5000);
  delay(1);
  noTone(2);
  delay(1);
    analogWrite(4, i);
  delay(2000);
  delay(2000);
silly_cone
And yes, I'm using your core.
silly_cone
Update:  Fixed; I was able to get around the problem using the TimerFreeTone library.
DrAzzy
This is a bug in my core. noTone() does not properly restore the state of TCCR1* registers.
DrAzzy
Issue with calling tone() repeatedly with the same parameters in a tight loop fixed for ATTinyCore 1.2.0
hpschawla
check this webpage out = TinyTone() = http://www.technoblogy.com/show?KVO
It helped my finish my ATTiny85 project!
