Topic: Voltage through a MKR1000 (Read 870 times) previous topic - next topic
joshyc
I recently got a MKR1000 and I need to run a motor using a 9 volt battery.
Any suggestion on if that voltage is safe for the voltage?
Aquaponics2016
The question you are posing does not make sense.   Your MRK1000 should only be used to "trigger" an action such as closing a contact on a "motor shield" that handles the motor load.
Does that help?
joshyc
I did not know the use of motor drivers but yes it helped
