Topic: Arduino Uno and CD4094 [Solved] (Read 1 time) previous topic - next topic
cinnamonBunny
Jan 15, 2017, 01:51 pm Last Edit: Jan 16, 2017, 06:42 pm by cinnamonBunny
I´m having trouble with Arduino Uno and a 16-bit shift register made out of two CD4094´s.
The program appears to be working, but the leds connected on the outputs of the shift registers do nothing. What am I doing wrong ?
Code: [Select]
#include <avr/pgmspace.h>
#include <SPI.h>
const int latchPin = 10;  //Pin connected to STR(pin 1) of HEF4094
//clock = 13, mosi = 11
const int eprom[12] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0x100, 0x200, 0x400, 0x800};
int address = 0;
byte i = 0;
  pinMode(latchPin, OUTPUT);
  digitalWrite(latchPin, LOW);
  SPI.beginTransaction(SPISettings(500000, LSBFIRST, SPI_MODE0)); // initialize SPI
  address = eprom[i];
  Serial.print(i);
  Serial.print(" ");
  Serial.println(address, HEX);
  Serial.println(" ");
  addressOut(address % 256, address / 256);
  i++;
  if(i > 11) i = 0;
void addressOut(byte addressLow, byte addressHigh)
  digitalWrite(latchPin, HIGH);
  SPI.transfer(addressLow);
  SPI.transfer(addressHigh);
  //delay(1);
PaulS
Did you try the code with just one shift register, first? Do you KNOW that the LEDs are connected correctly?
cinnamonBunny
#2
Jan 16, 2017, 06:49 pm Last Edit: Jan 16, 2017, 06:56 pm by cinnamonBunny
Hi
I got it working by replacing
Code: [Select]
with
Code: [Select]
SPI.begin();
SPI.setBitOrder(LSBFIRST);
And apparently Arduino needs to be connected to USB for the program to work at all (?)
(It would be interesting to know tough  why the version above didn´t work.)
Gustavo_Murta
#3
Aug 26, 2019, 04:06 pm Last Edit: Aug 26, 2019, 04:07 pm by Gustavo_Murta
Run perfectly with two HEF4094.
Thank You.
Code: [Select]
#include <SPI.h>
const int latchPin = 10;  // Pin connected to STR(pin 1) of HEF4094
int address = 0;
byte i = 0;
  SPI.begin();
  delay(1);
  address = eprom[i];
  Serial.print(i);
  Serial.print(" ");
  i++;
  if (i > 11) i = 0;
Gustavo_Murta
#4
Aug 26, 2019, 04:46 pm Last Edit: Aug 26, 2019, 04:55 pm by Gustavo_Murta
Running in FAST mode, use SPIMODE1.
Best without spurious pulses.
Code: [Select]
#include <SPI.h>
//clock = D13, mosi = D11
int address = 0;
byte i = 0;
  SPI.beginTransaction(SPISettings(500000, LSBFIRST, SPI_MODE1));       //  initialize SPI  500KHz
  SPI.begin();
  address = eprom[i];
  i++;
  if (i > 11) i = 0;
