Topic: Just wrote my first library. A driver for the L298 chip (Read 1 time) previous topic - next topic
spacedementia87
So while there are many drivers for various motor shields I noticed that there wasn't one for just the L298 chip itself or the various single chip modules such as this https://www.sparkfun.com/products/9670
I know it's not really.necessary to have a library for this usage but I wrote it so that my students can get started on the meaty bits of robotics nice and quickly after learning the basics of the arduino IDE.
Let me.know what you think. Feel free to submit issues if you see them.
https://github.com/jameshope87/L298Nbridge
PaulS
Why are the pin numbers to use hard-coded?
pinMode() assumes that the hardware is ready. When your constructor is run, that is NOT a valid assumption. Your class needs a begin() method where the hardware diddling happens.
Perhaps I'm missing something, but BRAKE and RELEASE seem to do the same thing.
spacedementia87
BRAKE and release do the same thing yes.
I realised to RELEASE I just needed to set the speed to 0.
OK so you are saying that I should have a method that I would call like this:
MS.begin(3, 4, 5, 6, 9, 10)
Which would set up the pinMode()
PaulS
Quote
Not exactly. The pins to use should be input to the constructor. The calls to pinMode() do belong in the begin() method.
spacedementia87
OK you have lost me a bit there.
Where would I enter the pin numbers if not when calling either begin method or motorsetup method?
PaulS
The constructor should take 3 pin numbers:
Code: [Select]
class DCMotor
  public:
    DCMotor(uint8_t motorNum, uint8_t aPin, uint8_t bPin, uint8_t dirPin);
    void begin();
The class should have three arrays of pin numbers:
Code: [Select]
  private:
    int aPins[2];
    int bPins[2];
    int dirPins[2];
In the implementation of the constructor, set the 0th element of each array, or the 1th element of each array, to aPin, bPin, and dirPin, respectively, based on the value in motorNum. camelCase is better than flatcase for names.
Then, your sketch would have:
Code: [Select]
DCMotor motorOne(1, 2, 3, 9);
DCMotor motorTwo(2, 4, 5, 10);
And, in setup():
Code: [Select]
    motorOne.begin();
    motorTwo.begin();
spacedementia87
Ahh OK!
Thank you
I have never had any formal lessons in c++. All I know from it is me fiddling with arduino and looking at other libraries and the such.
I get what you mean now. I just wasn't sure what you meant by constructor.
spacedementia87
Right I had a go at fixing it to allow for the user to select pins.
I think I have it working I would really appreciate it if you cast an eye over my new branch with these changes.
I have also made some changes to the names of various variables to match conventions.
https://github.com/jameshope87/L298Nbridge/tree/fix_constructor
PaulS
Quote
When I create an instance of your class, like so:
Code: [Select]
DCMotor motorOne(114, 2, 3, 9);
Where is your constructor going to store the pin numbers?
[ rant ]I REALLY hate variable names that have IN in the name being set to OUTPUT. It does not make sense. That the pin is connected to an INput to the motor driver is NOT a reason to use IN in the name. [ /rant ]
spacedementia87
Well as it is a driver for a dual H bridge they should.only define two motors.
I guess I should have a check in the constructor that checks the num = 1 or 2 and throw an error if not.
Out of interest though how do I make a list/array "expandanle" so that it will grow to whatever is needed?
PaulS
Quote
Well, as its your library, you should check for sane input before using it.
Quote
You shouldn't. You could use malloc(), realloc(), etc. to make dynamic arrays. But, you really shouldn't. There is no chance that the number of motors that one instance of your class, being based on hardware, can handle will change while the Arduino is running.
spacedementia87
OK I thought so,
I am struggling with this though.  I have included an if statement:
Code: [Select]
if (num == 1 || num == 2) {
//do stuff
else {
//bad input
however I am sure sure what to put in my else block.
Googling to how to throw an error just gets me lots of people asking about the errors they have!
Thanks for all the help you have given me, really appreciate it. I can see on this forum you spend a lot of time helping people like me and it looks quite frustrating ins some instances!
spacedementia87
Well now I have done a bit more research and made these adjustments:
Code: [Select]
DCMotor::DCMotor(uint8_t num, uint8_t Pin1, uint8_t Pin2, uint8_t enPin) {
  #if (num == 1 || num == 2)
    _motorNum = num;
    _Pin1s[_motorNum - 1] = Pin1;
    _Pin2s[_motorNum - 1] = Pin2;
    _enPins[_motorNum - 1] = enPin;
  #else
    #error "This chip is not supported!"
  #endif
however the error comes up whenever I try to compile regardless of the value of num.
I think I can see why, when compiling num has not yet been assigned a value and so it drops to the #else block.
in that case though, how do I make it through the error only when appropriate?
PaulS
Quote
The syntax for preprocessor statements is not the same as the syntax for if statements.
The "chip" part of the message is going to confuse the hell out of people.
spacedementia87
I know, the error message is just a random one at the moment as I am focusing on getting the syntax for throwing this error correctly.
I would appreciate it if you could show me how to get this problem handled properly.
At least point me in a relevant direction. I can't find anything to have it work.
