Topic: Serial Communication (Read 493 times) previous topic - next topic
AnkitSancheti
I basically have a text file on the pc, which needs to be displayed back on the pc as a ticker(like the stock market prices but instead of side to side it should be top to bottom).
Now i need to make a circuit such that i have push buttons which trigger a certain delay while the text file is being displayed so that there is a pause whenever required.
This should be done using the serial port.
Grumpy_Mike
All you need to do is to send a byte when a button becomes pushed. There is an example of this in the IDE, it is called "state change "
All the rest of the required function is done be the program you are writing on the PC, which is not an Arduino problem.
