Topic: warning: board bredboard :avr:atmega328bb doesn´t define a ¨build.board´ prefer (Read 1 time) previous topic - next topic
mdhc2
HOLA ESPERTOS DEL FORO, TENGO UN PROBLEMA Y NO SE A QUE SE DEBE, AL CARGAR UN EJEMPLO EN EL IDE DE ARDUINO, ME SALE ESTE CARTEL O CODIGO DE ERROR  MIENTRAS EL IDE ESTA COMPLILANDO Y NO LLEGA A SUBIR EL EJEMPLO, HAGA LO QUE HAGA, YA SEA QUEMAR UN GESTOR DE ARRANQUE O CARGAR LOS BOCETOS ME SALE ESE CARTEL SIEMPRE, YA PROBE TODO, LES DEJO LO QUE APARECE Y GRACIAS  DE ANTE MANO
Arduino:1.8.1 (Windows 7), Tarjeta:"Arduino/Genuino Uno"
Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
Opciones de compilación cambiadas, reconstruyendo todo
El Sketch usa 4060 bytes (12%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 472 bytes (23%) de la memoria dinámica, dejando 1576 bytes para las variables locales. El máximo es 2048 bytes.
Ha ocurrido un error mientras se enviaba el sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x91
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
pert
Code: [Select]
That warning can be safely ignored. It is completely unrelated to the cause of the failed upload.
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. Using code tags and other important information is explained in the How to use this forum post. Please read it.
