Topic: Understanding NAND (Read 3766 times) previous topic - next topic
p1ne
Regarding transistor circuits, I can see how the output of AND circuit works, but I'm not seeing how/why closing both switches turns the NAND circuit off (output above series transistors). Please lend some insight. Thanks.
CrossRoads
Output only goes LOW if both inputs are HIGH. Both transistors need to be turned on.
INs     AND    NAND
0  0     0        1
0  1     0        1
1  0     0        1
1  1     1        0
CrossRoads
Depending on the Vce of the transistors, that LOW could be as much as 1 to 1.4V. Have to be careful about mixing technology types.
Grumpy_Mike
Quote
If both transistors are turned on, the the output is effectively connected to ground so the output is low or a logic zero. I would not call that off but you could make a case for calling it that. In my mind the output is actively sinking current.
If one of both transistors are off the output is connected to 5V ( through R3 ).
MarkT
Logic signals are 1/0 true/false, high/low, active/inactive.  On and off is perhaps confusing in this context,
unless its some output device like an LED.  On/off usually applies to current flowing, most logic families
are voltage-level defined.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
p1ne
Please explain how if both transistors are turned on, the output goes to ground. That's the part I'm not understanding. Thanks.
septillion
And if you think of it as one transistor?
If the transistor is turned on (aka, on A or B there is a voltage) then there is a path through the transistor which leads to GND.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
Grumpy_Mike
A transistor can be thought of as a switch. When a little current flows through the base a lot of current can flow between the collector and emitter. So the emitter and collector can be thought as being connected together like a switch. So when a transistor is on the collector is connected to the emitter and the emitter is connected to ground. So anything connected to the emitter is also connected to ground.
MarkT
The transistors are either in cutoff or saturation when used as a switch, neither is much to do
with normal transistor action as used in amplifying a signal, which happens in the active region.
Think of it as a mechnical switch controlled by the base current being present or absent.
Grumpy_Mike
#9
Jan 20, 2017, 12:34 pm Last Edit: Jan 20, 2017, 12:34 pm by Grumpy_Mike
This is the equivalent circuit with switches. The switches are closed when current is applied to them.
The flashlight bulb only light up when both switches are closed.
p1ne
Thanks for replies and good to be reminded transistors can work as switches. Grumpy Like, following that example with both switches closed = light on, in 2 transistor example, why does all voltage run to ground and not power led when circuit is closed? In my thinking the voltage should hit the light even before it gets to transistors, unless closing 2 switches blocks ground, which does not seem to be the case.
The light being ahead of the transistors seems to be a key factor here that I'm not getting. Thanks for more explanation.
Grumpy_Mike
Quote
If you are thinking that the order of the components matter in a series circuit then you are not getting to grips with how electricity works.
A circuit has to be considered as a whole electricity does not hit anything first.
Quote
What circuit are we talking about here, that last one of mine or your original one.
For mine
The circuit is from the battery positive, through the flash lamp thus lighting it up, through one switch, through the other switch and then to the battery negative.
For the original one there is no LED in it and I don't know where you have it connected, but with both transistors on the current goes to ground and the voltage on the collector of the top transistor is at ground. So an LED connected from the top transistor's collector to ground will have no voltage across it and so will not light up.
However if the LED were connected to the collector of the top transistor and to 5V then when that collector was connected to ground the LED would light up.
There are two ways to control an LED the first is called sourcing current and the second is called sinking current
Note all LEDs must also have a series resistor. That is why I draw a flashlight bulb to make things simple.
Note to everyone except the OP. I am simplifying this by assuming that Vsat is zero, it isn't but that fact doesn't matter at this stage in the argument.
p1ne
Why is the output above the transistors in a NAND circuit, and below the transistors in AND circuit?
CrossRoads
#13
Jan 20, 2017, 05:05 pm Last Edit: Jan 20, 2017, 05:06 pm by CrossRoads
Does this help?
MarkT
I think its time to try this out on paper, figuring out what combinations of inputs causes the output
to be high or low.  Worth looking add wired-and and wired-or diode-resistor circuits too.
