Topic: Simple stepper program help (Read 464 times) previous topic - next topic
Johnredearth
Hi
I am new and want to get a simple pot controller to control the motion of stepper.  Ie half a turn to the left and the stepper mimics the movement and stops. Basically to work like a servo.  Ultimately once this is going want to make it respond to RC and use it on a model. However the first part is always the hardest.
I have NEMA 11 stepper, arduino uno, an easy driver and using Accelstepper library. External 12v on the easy driver.  I am trying to get the proportional  sketch to work in accordance with my needs without any success at all.  Analog-in is working properly.  Have modified as below.
I have tried to find 'starter code' to get going with this but this is the closest I can get to.
This does not work.
Code: [Select]
// ProportionalControl.pde
// -*- mode: C++ -*-
// Make a single stepper follow the analog value read from a pot or whatever
// The stepper will move at a constant speed to each newly set posiiton,
// depending on the value of the pot.
// Copyright (C) 2012 Mike McCauley
// $Id: ProportionalControl.pde,v 1.1 2011/01/05 01:51:01 mikem Exp mikem $
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
// This defines the analog input pin for reading the control voltage
// Tested with a 10k linear pot between 5v and GND
#define ANALOG_IN A0
  stepper.setMaxSpeed(1000);
  int val = analogRead(ANALOG_IN);
  val = map(ANALOG_IN, 0, 1023, 0, 1600);
  stepper.runToNewPosition(val);
PaulS
Code: [Select]
I can not see the value of mapping a constant pin number from some unrealistic range to another range.
Mapping the value read from the analog pin does make sense.
