Topic: SM130 with evaluation board problem (AUTH) (Read 616 times) previous topic - next topic
up201003803
hello,
I'm having problems with auth response.
My code:
Code: [Select]
  RFID Eval 13.56MHz Shield example sketch v10
  Aaron Weiss, aaron at sparkfun dot com
  OSHW license: http://freedomdefined.org/OSHW
  works with 13.56MHz MiFare 1k tags
  Based on hardware v13:
  D7 -> RFID RX
  D8 -> RFID TX
  D9 -> XBee TX
  D10 -> XBee RX
  Note: RFID Reset attached to D13 (aka status LED)
  Note: be sure include the SoftwareSerial lib, http://arduiniana.org/libraries/newsoftserial/
  Usage: Sketch prints 'Start' and waits for a tag. When a tag is in range, the shield reads the tag,
  blinks the 'Found' LED and prints the serial number of the tag to the serial port
  and the XBee port.
  06/04/2013 - Modified for compatibility with Arudino 1.0. Seb Madgwick.
#include <SoftwareSerial.h>
SoftwareSerial rfid(7, 8);
//Prototypes
void halt(void);
void parse(void);
void parse_auth(void);
void print_serial(void);
void read_serial(void);
void seek(void);
void set_flag(void);
void auth(void);
void print_auth(void);
void print_read(void);
void read(void);
//Global var
int flag = 0;
int Str1[11];
int Str2[7];
int Str3[21];
//INIT
  Serial.println("Start");
  // set the data rate for the SoftwareSerial ports
  rfid.begin(19200);
  delay(10);
  halt();
//MAIN
  if(flag==0)
    read_serial();
  if(flag==1){
    auth();
    delay(10);
    parse_auth();
    print_auth();
    flag++;
    delay(100);
  if(flag==2){
    read();
    delay(10);
    parse_read();
    print_read();
    flag++;
    delay(100);
void halt()
 //Halt tag
  rfid.write((uint8_t)255);
  rfid.write((uint8_t)0);
  rfid.write((uint8_t)1);
  rfid.write((uint8_t)147);
  rfid.write((uint8_t)148);
void parse()
  while(rfid.available()){
    if(rfid.read() == 255){
      for(int i=1;i<11;i++){
        Str1[i]= rfid.read();
  delay(10);
void parse_auth()
      for(int i=1;i<7;i++){
        Str2[i]= rfid.read();
  delay(10);
void parse_read(){
      for(int i=1;i<21;i++){
        Str3[i]= rfid.read();
  delay(10);
void print_serial()
  if(flag == 1){
    //print to serial port
    Serial.print(Str1[5], HEX);
    Serial.print(Str1[6], HEX);
    Serial.print(Str1[7], HEX);
    Serial.print(Str1[8], HEX);
    delay(100);
    //check_for_notag();
void print_auth()
  if(flag == 1){
    Serial.print(Str2[1], HEX);
    Serial.print(Str2[2], HEX);
    Serial.print(Str2[3], HEX);
    Serial.print(Str2[4], HEX);
    Serial.print(Str2[5], HEX);
    Serial.print(Str2[6], HEX);
    delay(100);
void print_read()
  if(flag == 2){
    Serial.print(Str3[1], HEX);
    Serial.print(Str3[2], HEX);
    Serial.print(Str3[3], HEX);
    Serial.print(Str3[4], HEX);
    Serial.print(Str3[5], HEX);
    Serial.print(Str3[6], HEX);
    Serial.print(Str3[7], HEX);
    Serial.print(Str3[8], HEX);
    Serial.print(Str3[9], HEX);
    Serial.print(Str3[10], HEX);
    Serial.print(Str3[11], HEX);
    Serial.print(Str3[12], HEX);
    Serial.print(Str3[13], HEX);
    Serial.print(Str3[14], HEX);
    Serial.print(Str3[15], HEX);
    Serial.print(Str3[16], HEX);
    Serial.print(Str3[17], HEX);
    Serial.print(Str3[18], HEX);
    Serial.print(Str3[19], HEX);
    Serial.print(Str3[20], HEX);
    delay(100);
void read_serial()
  seek();
  delay(10);
  parse();
  set_flag();
  print_serial();
  delay(100);
void seek()
  //search for RFID tag
  rfid.write((uint8_t)130);
  rfid.write((uint8_t)131);
  delay(10);
void auth(){
  rfid.write(0xff);
  rfid.write(0x09);
  rfid.write(0x85);
  rfid.write(0x01);
  rfid.write(0x38);
  rfid.write(0x59);
  rfid.write(0xa1);
  rfid.write(0x0d);
  rfid.write(0x43);
  rfid.write(0xf7);
  rfid.write(0x08);
  delay(10);
void read(){
  rfid.write(0xff);
  rfid.write(0x02);
  rfid.write(0x86);
  rfid.write(0x01);
  rfid.write(0x89);
  delay(10);
void set_flag()
  if(Str1[2] == 6){
    flag++;
  if(Str1[2] == 2){
    flag = 0;
I want to auth without a default key. I'm sure that is the correct key.
Code: [Select]
Start
569C69C
000000
028646CEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
This is my output. The second row (full of 0), should be my auth(response).
Thank you for your help,
best,
Pedro Cabral
